Clutch not fully engaging properly?
on
1 Post
1994 Bronco aftermarket 351 with Mazda 5 speed and hydraulic clutch. Recently the clutch does not seem to completely engage when the clutch is pressed to the floor. It is very hard to get into first gear (sometimes I can't even get it into 1st), slight grinding when upshifting in all gears and real grinding when shifting into reverse. This has come on gradually. I have checked the fluid level in the master cylinder and it was low but now out. I filled it but no improvement. The other thing the clutch pedal sometime won't come all the way back and I have to use my foot to pull it back to its resting position. Any suggestions?
WilliamKG88
1983 - 2012 Ranger & B-Series
04-20-2016 01:41 AM
