Alaska Chapter Join Chapter, Leader:
lift laws in alaska
Old 05-25-2011, 12:04 AM
hockeypuck000's Avatar
hockeypuck000
hockeypuck000 is offline
lift laws in alaska
So after my second $300 ticket for being lifted too high I've been trying to find a way to mess with the system without lowering my truck. Apparently the guy who drives the old primer gray chevy with the shell on 46" micky tompsons that sits at underground performance has found a loop hole by claiming his truck is either over 10,000 lbs or built to handle over 10,000 lbs. Whichever it was enabled him to change his GVWR to over 10,000 lbs which makes him exempt from frame height restrictions (basically putting him in the same class as commercial vehicles). I dont want to go into the dmv sounding like an idiot before I have a complete understanding of how it works. The GVWR on my excursion is 8,900 lbs. My 46" michelin tires probably weigh 200lbs each and then you add the 14" lift and was built to haul a huge fishing boat like its not even there, so I'm pretty sure I could get away with doing the same thing as he did unless I also need the 500 lbs of chains he has hanging off his truck. Anyone know anything about this and the steps I would have to take?
Old 05-29-2011, 10:55 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Maybe some of this info will help, or at least point you in the right direction to find what you need to know:
Alaska Lift Laws | Vehicle Modification Rules
Old 06-15-2011, 11:59 PM
hockeypuck000
figured it out..
need to register it as a commercial class vehicle. have proof of all the upgrades like axles, brakes, steering, etc. basically prove that the truck compares to an f450 or f550.
no more height limit for me so im going higher but I need to have a drop bumper fixed to the back of the truck similar to the same setup as a semi trailer so cars cant drive under me.
Old 06-21-2011, 12:13 AM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
Howdy neighbor.....
Be sure and post pics when you get it done.
Diesel_Brad
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
36
10-17-2013 09:10 PM
Screamin T/A
New Jersey Chapter
18
05-13-2011 08:45 PM
1994F2507.3L
40
12-26-2010 11:11 PM
Tiger_and_Apex
1999 to 2016 Super Duty
24
10-18-2010 12:12 PM
Mas360
27
08-27-2010 07:45 AM
Quick Reply: lift laws in alaska
