3.7, 3.5 and 3.0 Duratec V6 Forum for the 3.7, 3.5 and 3.0 naturally aspirated Duratec V6 Engines
2001 3.0 Escape Duratech engine binding.
Old 05-21-2011, 10:06 PM
clintonracer's Avatar
clintonracer
clintonracer is offline
Murphy's law strikes again!! I got a "low mile" (28K) 2002 Ford Taurus 3.0 Duratech motor that I'm going to use for my 2001 Escape. Well, things have hit quite a snag! I got the new timing cover and oil pan gaskets on and was getting ready to start putting on the alternator, power steering pump, etc. to start installing the engine back in and for the hell of it decided to turn the engine over by the crank bolt and it wouldn't turn over more than 1/4 turn in either direction!! It would not turn at all as if it was hitting something internally keeping it from turning past that 90 degrees or so. Now this is a used engine and it did turn freely way back 2 months or so ago when I checked it out when I bought it so I'm thinking "what exactly did I screw up??" So me being the worry-wort that I am I pulled off the timing cover and oil pan thinking a bolt had dropped in it somewhere or I had left a wrench in it or something stupid but it looked fine. I took the windage tray and oil pump pickup off too and all looked fine. Then I took the timing chains off of the crank pulley and the engine was still not turning over all the way. Now I'm thinking that something is wrong in the valvetrain so I took off the timing chains/tensioners, etc. and the cams out of one of the heads as well as the head itself. At that point the engine would turn over a lot more but not 360 degrees. So then I took off the other cams and head and then the engine would turn over as much as possible in both directions.
So was I just fighting the valve springs-lifters on 4 cams when the engine was fully assembled? I wonder if the lifters were sticking/seized due to the engine not running in a long time? I went over to my old engine with the head gasket/possible warped heads/block issue and it spun over like butter. I'm wondering if the timing was off on the used engine and maybe some piston-valve interference was going on?
I'm thinking too that maybe this was all just a big waste of time and the engine may have started up just fine once I got it in the car and used the starter to crank it.
Any ideas?
C.R.
P.S. I'll post this to the engine section too to see if I can get some feedback.
Old 07-09-2012, 07:04 PM
Brady Miclos's Avatar
Brady Miclos
Brady Miclos is offline
hi friend finally swap the taurus engine on escape 01? i want to swap just the block n use the escape heads manifold .....
Old 04-02-2013, 09:32 PM
clintonracer
Late Taurus to Escape Engine transplant update....
Well... It worked!!! 2002 Taurus 3.0 DOHC works JUST FINE in an 2001 Escape.. Just swap the timing cover, alternator, intake, motor mounts, and some other stuff I forgot about, from your wasted Escape motor onto the donor Taurus and it's all good.
Only kink was I had mixed-up two of the coil-on-plug wires on the front left side of the motor (timing cover side.) The way the old harness lies you'd swear the coil-on-plug wires go differently BUT the Ford factory wiring diagrams don't lie..
Used Taurus 3.0 DOHC motors are a LOT less than Escape or Tribute ones in the junkyard. Plus you pull the Escape/Tribute motor/trans as an assembly out the top and it's not actually too bad.
Sorry for the late report back... Just some words of wisdom.. Bad coil-on-plugs ruined ALL THREE CATS on this vehicle and probably took out the first engine due to all the backpressure... Front 2 cats were mostly plugged and the third one (under the car) was probably 3/4 plugged as well from the front two cats tossing their innards backwards.. Rock Auto has Mustang coil-on-plugs for cheap that will work on the Escapes/Tributes and the only difference is that the coil-on-plug's electrical plugs point in a different direction but there is plenty of harness for them to plug in.
DH
Rick_Fury
03-29-2019 01:39 AM
Jimmyskalla
Modular V8 (4.6L, 5.4L)
12-16-2015 03:35 PM
rsm688
08-15-2015 11:22 PM
Widall1
19
08-15-2012 03:22 PM
acertm
05-11-2009 10:40 PM
Quick Reply: 2001 3.0 Escape Duratech engine binding.
