1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
2WD Front wheel bearings
Old 05-20-2011, 10:28 AM
C. Lee Colbert's Avatar
C. Lee Colbert
C. Lee Colbert is offline
I need to replace my front wheel bearings on a 2WD Ranger...any suggestions?
Old 05-20-2011, 11:45 AM
g_k50's Avatar
g_k50
g_k50 is offline
I just did mine on my 1999. Scheduled maintanence for the 1999 calls for inspect and adjust every 30,000, lubricate at 120,000. Pretty easy to do, no special tools required, use Ford parts only.
Old 05-20-2011, 11:49 AM
Rangerman Stan's Avatar
Rangerman Stan
Rangerman Stan is offline
Might as well replace the grease seals too, since they have to come out anyway. But maybe that was already on your list. How many miles on your "97"? If you don't have a torque wrench to set the bearing pre-load you can do this: To set the wheel bearing torque WITHOUT the torque wrench, just tighten the adjusting nut very snug to seat the inner and outer wheel bearings on the spindle; (making sure they are PACKED with fresh grease first) and then back off on the adjusting NUT until the wheel spins freely with no play in it. Put the nut-lock on and the cotter pin back in and you're set.
Old 05-20-2011, 01:14 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
I dont know about using ford only bearings, just go to a bearing house and get some good ones along with the seals. will be a lot cheaper, but if you take care of the bearings even those from a parts house will last. I have 300K+ on my 94 and got the bearing at napa or from checkers cant remember! Anyhow the PIA is to change the races if/when you do R&R the bearings.
Old 05-20-2011, 06:36 PM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
If you get the bearings from a Napa with a machine shop they can turn rotors and install the new bearings/races and repack with grease. Only thing you need to do is reinstall em. Not sure of the additional cost but money well spent for making the job easier.
Old 07-03-2011, 12:32 AM
C. Lee Colbert
I ended up bringing it to a shop near my house, & good thing too...there was a lot more work needed then I could do myself. But it is all fixed up now & ready to go!
PaulTMurphy
06-02-2017 05:18 PM
bhost1
2009 - 2014 F150
04-28-2017 08:38 PM
BroncoRN
02-20-2017 01:28 PM
72GTS
06-15-2016 09:23 PM
johnsteffy
09-23-2010 10:21 AM
Quick Reply: 2WD Front wheel bearings
