cam timing marks
Old 05-12-2011, 06:02 PM
graybird78's Avatar
graybird78
graybird78 is offline
cam timing marks
question is regarding timing marks on cam shaft gears; what are the marks supposed to look like? passenger side gear has what looks like an "L" with an arrow at the top. mitchell on demand shows 1 of 3 posibilities; an "R" with an arrow at the top of it, a "O" with a "R" next to it, an elongated mark. not sure which diagram to go by... yet another picture shows crank shaft marks at 6 o'clock position elongated mark at 12 o'clock mark on passenger cam gear. elongated mark at about 2 o'clock on drivers cam gear & says this is verifying correct alignment of all timing marks. motor in question is in an 05 f150 xlt. only the passenger side is off; the gold links are ligned up with a "L" at the arrow at the top. truck is setting code poo12 (cam shaft timing retarded bank A). truck has slight rough idle, no power.
Old 05-13-2011, 07:38 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Read my posts in this thread: https://www.ford-trucks.com/forums/7...g-a-5-4-a.html
You need to pull the timing cover and set up both cams as described.
macubus
2004 - 2008 F150
08-03-2019 01:03 PM
Azuber01
01-19-2017 08:22 PM
Obowersox26
09-17-2016 09:21 PM
deputydog03
Modular V8 (4.6L, 5.4L)
32
04-09-2016 12:06 AM
CR's Ford f250 SD
1999 to 2016 Super Duty
07-09-2011 02:43 PM
Quick Reply: cam timing marks
