97 f150 overdrive light blinking
Old 05-12-2011, 03:36 PM
memphis_made's Avatar
memphis_made
memphis_made is offline
my over drive light is blinking and when i hit 20 it bogs down then u have to stomp on it in it revs back up and gose it says its in 4x4 low on the dash but it doesnt feel like it is idk where to start on this anybody know what this is?
Old 05-12-2011, 05:20 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Need to pull the codes and stop driving it if at all possible. The blinking is the transmission warning light telling you there is a problem.
Old 05-12-2011, 06:34 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Funny things happen.
Get the codes read first.
As an example only; If a certain fuse were to blow from an electrical fault such as a shorted OX sensor heater circuit, it takes power off from the shift solenoids, torque convertor clutch and a bunch of other operations and causes all kind of 'goings on' until someone is smart enough to figure it out.
A trouble like this takes looking at the wire diagram to discover that the power the fuse feeds goes to 'SEEMNGLY" unrelated places until you see in on the drawings.
How it all started was with a string of codes referring to a number of different areas but tuned out to be all common to "one" fuse.
This is a real time example I have already had, that a trans shop could not figure out.
Need to see the codes first to get a direction on the issue. We cannot guess the fix or trouble ahead of it.
Good luck.
Old 05-12-2011, 10:55 PM
memphis_made
no check engine lights are on so i dnt think its throwing anycodes
Old 05-13-2011, 12:35 AM
Bluegrass 7
Transmission codes are in the 7xx range and not engine related if the issue is in the transmission.
The CEL light may not come on for example if a clutch in the trans is slipping.
It's not electrical in nature so the PCM cannot detect it.
Be sure about it because you are having an issue for some reason.
Old 05-13-2011, 10:34 PM
memphis_made
its weird i un hooked the battery to reset it because it wouldnt start now its shifts fine no blinking light nothing i think i have some electrical issues
thr57
1997 - 2003 F150
07-17-2017 09:30 PM
couverley
05-07-2017 11:41 AM
97explorerjunk
01-05-2017 06:18 AM
smashclash
1997 - 2003 F150
45
09-17-2014 02:17 PM
Dutter
1983 - 2012 Ranger & B-Series
07-27-2011 11:38 AM
Quick Reply: 97 f150 overdrive light blinking
