Mississippi Chapter Join Chapter , Leader: Scndsin
1987 F-350 6.9 (HELP)
Old 05-07-2011, 07:46 PM
gatormccluskey's Avatar
gatormccluskey
gatormccluskey is offline
Is the oil cooler next to the oil filter. If it is I have water coming out of the plug by the oil filter. I was going to install a manual oil gauge at that location. When I started taking the plug out, water started dripping. I didn't take it all the way out.
Old 05-08-2011, 07:20 AM
3golfjack's Avatar
3golfjack
3golfjack is offline
I change out this sensor plug on the 89 I had a while back. Normally you need to drain your oil or oil pours out of this plug. I would pull the dipstick and check to make sure it isn,t white creamy. Hopefully you do have a outside source for your water and its not coming out of the oil.
Old 05-08-2011, 09:36 AM
gatormccluskey
The oil is not milky. I have heard if you let truck set for a long time condensaion will build up. I am new to the 6.9. I bought the truck about 2months ago and it had been setting for a long time. Thanks for your reply.
Old 05-08-2011, 06:54 PM
3golfjack's Avatar
3golfjack
Like you said I've heard condensation can build up in a motor which sets up a long.
guyspencer
12-12-2013 05:10 PM
rshiver
11-21-2011 05:47 PM
Molineguy
10-10-2011 09:09 PM
1990FordF250Diesel
08-31-2011 11:47 AM
tjones2269
02-24-2005 07:09 PM
Quick Reply: 1987 F-350 6.9 (HELP)
