1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 SD Daytime Running Lights
Old 05-06-2011, 10:32 PM
Hawk180's Avatar
Hawk180
Hawk180 is offline
Is there any way to disable the daytime running lights without disabling the fog lamps? They are on the same fuse so that's not an option. I was wondering if the running lights had a relay that could be removed without disabling the fog lamps.
Old 05-06-2011, 11:21 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I wasnt aware that these trucks had DRL.
Old 05-06-2011, 11:32 PM
Hawk180's Avatar
Hawk180
Hawk180 is offline
Well mine does, whenever you turn on the ignition switch, the headlights come on in a reduced capacity. After reading the owner's manual, it is a feature (I suppose it is optional).
Old 05-06-2011, 11:48 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
Canadian. And yes there should be a relay, remove that and no drl.. As for fog lights with no parking lights probably not. You will likely have to wire up that switch your self
Old 05-06-2011, 11:51 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
My fogs wont come on with the parking lights. They only come on with the headlights. Is there a way to fix that?
Old 05-07-2011, 06:55 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
That's the way Ford used to do it. No headlights, no fog lights. But they did change that, not sure when though. I hada Mustang that was the same way. You either rewire the fog lamps or just deal with it.
Old 05-07-2011, 07:24 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Ahh. My previous truck, a 2005 F150, allowed the fogs without headlights. My guess is it changed in 04 with the body style change. And 05 for the superdutys.
Old 05-08-2011, 01:01 AM
9402fordguy's Avatar
9402fordguy
9402fordguy is offline
Between myself and 3 friends we have 4 Super Duty trucks; 01, 02, 02, 06
Only the guy with the 01 is unable to run the fogs/markers WITHOUT the headlights on... the rest of our trucks all work the good way, lol. So I would think it was changed for 02 apparently.
Old 05-08-2011, 06:36 AM
grec-o-face's Avatar
grec-o-face
grec-o-face is offline
To the OP, I once heard that there was some sort of fusible link found below the radiator area on the driver's side that when disconnected with disable the canadian DRLs. I've never actually seen it - but I was told it's an orange wire.... ???
As for the Fogs;
My 02 allows me to run Fogs w/OUT headlights. I think it's got something to do with my auto headlight option.
My friend's 02 is not this way, but we pulled the switch apart and modified it to allow for Fogs w/OUT heads. There is some good info on these pages:
How to modify the Headlight Switch to allow Fog Lamps to come on with Parking lights and Autolamps
S&S Diversified
Here's my non-modified (HID outfitted) fogs ON with headlights OFF.
Old 05-16-2011, 02:51 PM
Hawk180's Avatar
Hawk180
Hawk180 is offline
I found the resistor for the DRL's mounted on the back of the left headlight bucket. Removed it and potted the connector with silicone. No DRL, Foglights still work....Thanks for all the replies..
Old 05-16-2011, 02:56 PM
grec-o-face
Glad to hear it all worked out!
Old 05-16-2011, 04:41 PM
jc8825's Avatar
jc8825
jc8825 is offline
You should be able to turn the headlight **** to P (Parking lights) and pull out on the ****. That is fog lights without headlights.
Old 05-16-2011, 04:53 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I can do that but the fogs stay off.
Old 05-16-2011, 05:31 PM
jc8825's Avatar
jc8825
jc8825 is offline
The fog indicator doesn't light up? That's strange.
jetmagnum
05-19-2023 10:21 AM
surreyboy
6.7L Power Stroke Diesel
11-02-2015 12:07 PM
nick4833
12-24-2008 01:04 AM
Steve98592
12-16-2004 02:59 PM
storeboy98
1983 - 2012 Ranger & B-Series
10-22-2003 02:27 PM
Quick Reply: 2001 SD Daytime Running Lights
