dual exhaust..what to do with o2?
Old 05-04-2011, 10:36 PM
DAVEXFORD's Avatar
DAVEXFORD
DAVEXFORD is offline
Lightbulb dual exhaust..what to do with o2?
i am putting true duals on my 90 f150 and im not sure what to do with the o2 sensor..run one to wach pipe?use an ''H'' or ''X'' pipe? someone please help me
Old 05-04-2011, 10:39 PM
86F150302's Avatar
86F150302
86F150302 is offline
Just put it on one side.
I have mine in the H pipe.
Old 05-04-2011, 10:45 PM
DAVEXFORD's Avatar
DAVEXFORD
so i can just put it on one side and it wont affect the way my truck runs? the kit im buying from summit dont come with an H pipe..i just dont wanna get it all together and then it run rough and have to take it apart..thanx for the reply
Old 05-04-2011, 10:56 PM
86F150302's Avatar
86F150302
Nope it will run just fine. I ran my old F150 like that and im sure many many others on here do too.
Old 05-04-2011, 11:25 PM
JEAkridge's Avatar
JEAkridge
JEAkridge is offline
You can do away with down stream O2 but you can not do away with up stream O2's. Sensor on one side truck will run just fine computer doesn't know that it has true duals after '02.
Old 05-05-2011, 12:06 AM
DAVEXFORD's Avatar
DAVEXFORD
what exactly do you mean ''upstream,,downstream''????
you sayin i dont need the bottom sensor atall??
what would i do with it?
thanx very much guys i appreciate it alot
Old 05-05-2011, 12:30 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Newer trucks (97+ I think) have an o2s before the cat and one after, you only have one just put it somewhere convenient.
Old 05-05-2011, 02:28 AM
86F150302's Avatar
86F150302
Ignore that post. Doesn't have anything to do with your truck.
Your welcome. Good luck with the exhaust
Old 05-05-2011, 02:47 AM
DAVEXFORD's Avatar
DAVEXFORD
thank you sir
Old 05-05-2011, 05:57 AM
cjben's Avatar
cjben
cjben is offline
Your engine will run fine reading off of one bank,my 95 has been that way since I put headers on it 2 years ago.
Old 05-05-2011, 10:05 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
Mine is the same w/ headers.
Put it in the passenger side pipe, as close to the same place front - to - back as you can get it. Try not to have it any farther away from the motor is what I'm saying.
Old 05-05-2011, 11:04 AM
73FOMO's Avatar
73FOMO
73FOMO is offline
If your truck isn't already equipped with 2 upstream o2's the eec is only seeing one bank anyway. It has no way to adjust fuel to two banks, so it doesn't matter which side you put it on, it will work fine (but read exception below). Also, if you ever get a CEL, the code will default to bank1-right side, but it could be either causing the CEL. This makes trouble shooting a little harder on one upstream o2 sensor trucks because it doesn't distinguish banks.
Just fyi though...the factory uses a little connector pipe right before the cat on the y-pipe to read exhaust from both sides.
The only way putting in one bank could possibly hurt you would be if the other bank is running real lean and it is not detected in the exhaust because the o2 is located way upstream in the other bank. Personally I would try and get exhaust from both banks from an H pipe.
Old 05-05-2011, 12:48 PM
Skinsfan6's Avatar
Skinsfan6
Skinsfan6 is offline
I am running true duals with the O2 sensor only on the passenger side ~6 inches below the collector. It has been this way for a year. I have never had a CEL or any change in fuel mileage, etc.
Old 05-05-2011, 01:14 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
73FOMO-CLEAN OUT YO INBOX FOO......
Old 05-05-2011, 04:21 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
I know...it's tapped out. I'll try and get over and delete some of the crap.
Quick Reply: dual exhaust..what to do with o2?
