I need a fuse diagram for my 1996 Ford F250 XLT 5.8L FI
Old 05-03-2011, 03:45 PM
Lady.Connoisseur's Avatar
Lady.Connoisseur
Lady.Connoisseur is offline
I am having a crisis [my nerves are shot]; my center tank stopped working and will not work at all; it's full of gas. my rear tank shut down yesterday while I was driving, then ran normally; just around the corner it shut down altogether, we had to coast into gas station [think gauge is going, it read 1/8 tank], put 3 gallons in, runs fine now. Let me preface this by giving some history, to see if it would explain what I am experiencing.
bought truck used in 2007, keep both tanks full, engine & trans good condition, all fluid levels ok.
upon last filling of both tanks, added STP gas treatment & Octane Booster to each tank. one week later, front tank stopped operating while my husband was driving. This morning i took truck to Autozone for scan, my data link didn't work, so couldn't get any codes; have no idea about fuel pressure. tried to switch FUEL RELAY FUSES myself to see if one was bad, but I don't know if I acutally found them or not...I have found two fuse boxes, driver's side next to fire wall comprised of many fuses and one little box that reads RELAY 1, RELAY2 [i exchanged fuses but noticed no change, truck would stall out on start both times when running on rear tank, switching to center tank] inline filter cannot be problem because both tanks would shut down. I need a diagram of all fuse panels/boxes, so I can try to find problem; hoping it's a $10 [fuel relay fuse] instead of $532 [for a new pump, etc installed and guaranteed]. If you have any suggestions, please don't hesitate to pass them on to me. Thank you
Old 05-03-2011, 04:41 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Talk to Bill; AKA Subford.......He has all the wiring crap on here....
Old 05-03-2011, 06:24 PM
subford's Avatar
subford
subford is online now
The little box that reads RELAY 1, RELAY2 is for when you pull a trailer.
Sounds like all of your fuses are OK.
Hard to tell if you have a fuel problem or a distributor problem.
Autozone can not scan your truck as your truck is an OBD-1 truck with the scan port under the hood and Autozone can only scan OBD-2 trucks.
Get a $30.00 scanner at O'Reilly auto parts like this one:
Fuel wiring:
Phobia16V
36
01-18-2021 04:01 PM
Jammer-1
04-14-2017 09:43 PM
snorindad
04-02-2017 07:01 PM
AZ_Mike
10-08-2016 12:18 AM
Rhino99
Modular V10 (6.8l)
02-21-2016 06:11 PM
Quick Reply: I need a fuse diagram for my 1996 Ford F250 XLT 5.8L FI
