1989 F250 460 runs great, horrible idle
Old 05-05-2011, 02:00 PM
Wayne U's Avatar
Wayne U
Wayne U is offline
Originally Posted by 4 flat tires
try running without the spout, it should at least idle.. did you do this when you set the timing? did it idle decent then? also check the wires out for it, maybe switch one from another truck with the same motor if you can. i have no idea of what the code means, i'm just throwing stuff out there.
i pulled out the spout and it runs the same. set the timing with the spout out and it all of a suden idels perfectly. of course i got excited and took it for a drive and it had no power to accelerate but no longer missfiring at all hardly. it apears on my system pulling the spout makes no difference so there must be a bad wire some where or mabe the ignition module on the distributor? i cant find any bad wires but could it possibly be the ign module?
Old 05-05-2011, 06:11 PM
BigRedFordTruck's Avatar
BigRedFordTruck
BigRedFordTruck is offline
Yes. Replace it. Keep the receipt and be careful installing it. If it doesn't work, return it. It's a five minute job on that engine to swap it out. You are living the almost identical thing I went through last year. I did the wires, plugs, hoses, the whole deal. A bud on here told me to check the IAC. Mine LOOKED fine-swapped it out and she's running like a top now. It'll set you back $40.00 or $50.00 bucks, but I think it'll help. If not, return it. Hope it helps ya. These trucks are a lot of fun!
Old 05-07-2011, 11:52 AM
4 flat tires's Avatar
4 flat tires
4 flat tires is offline
the spout gives electronic timing advance to the distributor... short for spark out... thats why you didnt have power when driving with it out. the tfi module on the distributor does have a tendency to fail, but my experience is that it just shut off and wouldnt fire. and if it did was random at best... didnt cause idle issues. i'm still leaning towards vacuum leaks... there are alot of lines that are hidden in wire looms and such. a thing to check as well is the fuel vapor lines between the charcoal can, tank, and intake. there is a valve that controls flow in the engine compartment.
Old 05-12-2011, 02:53 AM
Wayne U's Avatar
Wayne U
Wayne U is offline
ok heres an update... finally got some money together and got a tfi for the ignition. still hard to start and idles bad but when warmed up it idles perfectly and has more power than ever. so spout was bad but next step is to replace the IAC valve and hopefully that should help with hard to start and rough idle when cold. paycheck should be in tomaro so ill let yall know how it goes.
Old 05-12-2011, 03:09 AM
fuftransport's Avatar
fuftransport
fuftransport is offline
there is a crank secer on that can make it attack all funny at low rpm's
Old 05-14-2011, 01:20 PM
Wayne U's Avatar
Wayne U
Wayne U is offline
ok the new IAC is on and the truck runs great. all you can hear is a very random faint missfire sometimes on idle but other than that it runs beautifully, thanks for everyones help on this issue but now i must go fix a new problem that happend five minutes after installing the IAC. my front seal blew out on my transmission and its running out like a faucet. this is going to be a fun weekend pulling a tranny
Old 05-19-2011, 11:40 AM
Wayne U's Avatar
Wayne U
Wayne U is offline
ok well all is almost well we got the trans back in after having to replace the pump bushing and seal that goes around the torque converter and the leak went away but the darn check engine light came back again!(this truck is driving me nuts) it wants me to replace the evp guess ill give it a shot when i get paid again. the running code was 31.
Steve
18
06-03-2014 04:24 PM
trozei
24
05-05-2014 01:55 PM
whintyr
03-13-2014 10:25 PM
Pad2383
15
11-04-2012 01:30 AM
Ray620
1999 to 2016 Super Duty
23
07-21-2012 06:50 PM
Quick Reply: 1989 F250 460 runs great, horrible idle
