How do I grease upper ball joints?
Old 04-29-2011, 02:16 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Question How do I grease upper ball joints?
So I put in Ed's kit yesterday (all 4 balljoints, new seals, o-rings) and also did the autolock hub clean and lube, needle bearings clean and lube, and replaced my caliper slide pins (had to get another caliper bracket for the passenger side though since one of the pins was rusted solid).
Anyhow, now to my real question. The balljoints came with strait grease fittings. I read somewhere that the 90* fittings aren't good for the top because the 4x4 axle will hit it. But how the heck do I grease the strait fitting?! I can't for the life of me figure this out.
Is there a special fitting for my grease gun? or will I need to screw in 90* fittings everytime I want to grease these?
Old 04-29-2011, 02:20 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
I recently ordered this, We will see if it does the job when it gets here:
Amazon.com: Lincoln Lubricating Equipment LNC-5883 Hydraulic Coupler Assembly 90 Degree Bend: Automotive
Old 04-29-2011, 02:32 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
That looks like it would do the trick. Let me know how it works!
In the mean time, has anyone else come up with any tricks?
Old 04-29-2011, 05:44 PM
rtazz17's Avatar
rtazz17
rtazz17 is offline
yes I screw in a 90 degree fitting everytime I grease them,not that hard ,lift both wheels off the ground when you grease them.10 minute job..There was no way to leave a straight fitting in there,it wouldve got crushed on my truck...
Old 04-29-2011, 06:49 PM
hammer65's Avatar
hammer65
hammer65 is offline
It does the job for me.
Old 04-29-2011, 11:17 PM
izzybird's Avatar
izzybird
izzybird is offline
Same here.
Old 04-29-2011, 11:56 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Found one of those at my local O'Reillys for $9. Works good.
Old 04-30-2011, 06:44 AM
Rich in CO's Avatar
Rich in CO
Rich in CO is offline
I use the 90 coupler also works like as charm, picked one up a the local Nappa
Old 04-30-2011, 08:55 AM
Waltdog's Avatar
Waltdog
Waltdog is offline
Got my 90 degree adapter from Lincoln. It works great. I installed the low profile strait zerks when I did my ball joints. This fitting locks right on and does the job.
karljay
06-21-2016 12:38 PM
JohnnyAirtime
04-14-2016 05:43 PM
bigred66
1999 to 2016 Super Duty
06-08-2010 09:11 AM
kosb
07-02-2009 05:01 PM
CruiserClass
05-02-2007 05:57 AM
Quick Reply: How do I grease upper ball joints?
