Power steering box?? How to adjust?
Old 04-28-2011, 01:10 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
Exclamation Power steering box?? How to adjust?
Hey yall, I have some play in my ps box and i read there is a screw u can adjust to have less play. How much should i turn it and what direction? Thanks.
Old 04-28-2011, 02:06 PM
F150xlt's Avatar
F150xlt
F150xlt is offline
Post #20 in this thread describes the proper way to adjust the steering
gear box sector shaft screw. Using any other method is guess work.
https://www.ford-trucks.com/forums/8...teering-2.html
If you choose to adjust it by trial and error, you loosen the lock nut and with a
flat blade screwdriver turn the screw clockwise to take up any slack. Don't
turn the screw more than 1/8 of a turn at a time. Take it for a test drive and
adjust again if needed. Warning if you tighten the screw to much, you can
lock up the steering box.
Old 04-28-2011, 02:27 PM
snaponprofile
Thanks alot man.
texasjack
40
07-30-2023 12:04 PM
olblue76
12-22-2014 09:30 AM
77429highboy
06-19-2011 08:58 PM
79FordBlake
04-17-2010 12:13 AM
jplinville
02-06-2010 07:42 AM
Quick Reply: Power steering box?? How to adjust?
