Ford 351m/400 and 429.460 bell housing depth
I have been told that the depth of the bell housings on the 351m/400 is different then the 429/460. 351m/400 housings are easier to come by and i was wondering if one would bolt up to a 460, i know the pattern is the same but is the depth the same?(4 speed manual transmission.)
I'm getting ready to do just that, use a 400 bellhousing on a 460. On my first attempt I found there is a depth difference, took it all back apart, and left it for a couple of years due to other projects. Since I have found that you can use spacers and make it work but I do not have any measurments made or materials selected. I need to mate them back up and see how much space there is first. I'm open to ideas and suggestions if anyone already has this info...
You should use a scattershield. That 500 horse motor, think you'll ever tear up or blow up a clutch? How fast does it rev, over 5500?
That potmetal 400 bell is just going to end up imbeded in your legs if something goes wrong.
Just a thought....
Still think a C6 is the better way to go....
Just a thought....
Just a thought....
Just a thought....
I guess thats about the only way to do it...probably the hard way, But if I cant find a 460 bell then that would be the way to go. Sliding the transmission in all the way, I would imagine back it out a 1/16 or 1/8 of an inch so the surface or tip of the shaft wouldn't ride on anything...then add that to the thickness of the spacer plate.
Well, when we get to that point we will figure it out...I will go to my local salvage yard sometime this month and see if I can find a 460 bell from a truck or van, its not like a bell housing is a hot ticket item, when ever i go there the last usable parts in the truck that has been there a long time is the trans and bell.
bell housing switch
There is a spacer you can buy to allow the use of a 351m and a 400 bell housing on the 460 and 429 block it is sold by six states clutch in salt lake city
