10 DTC's; what do the codes mean?
Hi. This is a follow up to this thread;
https://www.ford-trucks.com/forums/1...-stranded.html
2006 F250 6.0 Crew 4x4 110000miles
Truck was running fine. Suddenly wrench light comes on. Then the check engine light. Truck will only idle at about 750rpm. Shuts off on its own after a few minutes. I scanned it and got 10 codes. Can someone please make sense of them and tell me what is actually wrong. ETC, IPR, VGT, VREF?????
Here are the codes. Can someone decode this for me please? Thanks.
P0107 MAP/BP Sensor Circuit Low Input
P0405 EGR A circuit low
P0472 Exhaust Pressure Sensor Low
P2104 TAC System - Forced Idle
P2122 Throttle/Pdl Position Sensor Switch 'D' Circuit Low
P2127 Throttle/Pdl Position Sensor Switch 'E' Circuit Low
P2132 TP/APP Sensor/Switch F Circuit Low
P2138 Throttle/Pdl Position Sensor/Switch 'D/E' Corelation
P2139 TP/APP Sensor/Switch D/F Voltage Correlation
P2285 ICP Sensor Circuit Low
David Chamberlain posted this in the prior thread;
dchamberlain
Garage is empty, add now Join Date: Sep 2007
MAP, EGR, EBP, APP and ICP sensors all giving codes. Each one of those sensors rely on VREF (conditioned, regulated +5V from the PCM).
I'd bet that you have a shorted VREF wire somewhere. How to test that and find it, I haven't a clue. One of the smart techs will have to help you with that.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member: To join the Oregon Chapter, click HERE
dchamberlain
__________________
David Chamberlain
I can't find an obvious wiring problem.
When checking the fuses though, the entire right side of the cab fuse box wasn't getting power. I was checking the fuses with a test light instead of pulling each one, and the whole left side lit up, but the right side fuses had no power to them. I'm pretty sure that most of them used to light up when I checked them.
The fuses under the hood wouldn't light up either.
EDIT: Actually I remembered they should work with key on, and they do, except for four on the far right middle.
Also, in the DTC code analysis, it says the problem for most of my codes could be a short somewhere, as David Chamberlain said earlier.
It says there is a 'Pinpoint S for 12 way conn. diagnostics'. It says there is a main 12 way wiring harness/connection that delivers power and ground to all of the sensors. The pinpoint test will help find the cause I assume.
For the; P0107- pinpoint test H
P0405 pinpoint W
P0472 pinpoint X
P2285 pinpoint Q
the rest pinpoint AG
I don't know how to do these. I have access to a high quality scanner, a Snapon Mobis Elite, can it do these pinpoint tests?
It looks like I may have to go to a dealership.
P0405 pinpoint W
P0472 pinpoint X
P2285 pinpoint Q
Then it's time to attack P0107, P0405, P0472 and P2285. But that's for another thread.
I hooked it up and here is what I found;
APP % 0
. no thr. 1/2. full
APP 1 v 0.91 0.45 0.13
APP 2 v 0.34 0.65 0.91
APP 3 v 0.22 0.53 0.79
APP_Low v 0.00
EBP v 0.05
ECT v 3.31 (no fault)
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
TBC FAULT when I tried to start it
I'm not sure what it all means. Any help would be appreciated.
APP % 0
. no thr. 1/2. full
APP_Low v 0.00
EBP v 0.05
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
APP % 0
. no thr. 1/2. full
APP_Low v 0.00
EBP v 0.05
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
APP % 0
. no thr. 1/2. full
APP_Low v 0.00
EBP v 0.05
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
What does the wiring to the accelerator pedal look like? Is it all chewed up or completely intact?
