Cigarette lighter wiring question.
Old 04-18-2011, 08:56 PM
Highboy74's Avatar
Highboy74
Highboy74 is offline
'74 highboy and I was looking at why my cigarette lighter wasnt working. Well, after further inspection someone cut the wire. Does anybody know where it plugs into or where it ties into. I want it to use for my radio because I know it is a constant "hot" lead.
Old 04-18-2011, 09:00 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
There should be a 3-connector pigtail hanging behind the glovebox. The cigarette lighter should plug into one of these spots.
The wiring for the pigtail itself is GREEN with a YELLOW stripe. GREEN with a YELLOW stripe is hot-at-all-times power for the courtesy lamp circuit. I use this for the constant power to my radio as well.
Old 04-18-2011, 10:45 PM
Highboy74's Avatar
Highboy74
I saw the wire your talking about, however, I didn't see the pigtail your talking about. I saw an empty single pigtail with the green and yellow wire and another green wire. The cigarette lighter wire is solid black and routed over to the drivers side area over the steering column (factory style).
Old 04-19-2011, 08:51 AM
76F15OSuper's Avatar
76F15OSuper
76F15OSuper is offline
Originally Posted by fmc400
T
A little Funny , In my bushiness (Industrial controls) A Green/Yellow wire is GND. I wish wire colors where the same across the board.
Old 04-19-2011, 02:32 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
Green/Yellow should be the cigarette lighter wire color. It ties into the circuit with the glove box switch and lamp, door jamb switches, and dome lamp...which run through the green/yellow wire at the headlamp switch. All are powered from the green/yellow wire coming from the 15a fuse in the fuse panel.
Old 05-20-2011, 10:09 PM
Ryank78shortbed's Avatar
Ryank78shortbed
Ryank78shortbed is offline
Anybody know what the black with yellow stripe wire behind the instrument cluster is it has three plugs in it? And what circuit is it on!
Frmnsal
15
05-28-2018 04:04 PM
phurst
39
10-04-2017 12:53 AM
Poor'it in'her
1999 to 2016 Super Duty
05-05-2014 09:53 AM
5.4f250sd
11-10-2010 08:45 PM
Quick Reply: Cigarette lighter wiring question.
