5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
coyote with a zf 5-speed
Old 04-18-2011, 10:21 AM
mark73899's Avatar
mark73899
mark73899 is offline
Does any body know if the 99-up zf 5-speed for the 4.6l will work with the new coyote 5.0 engine ,an the ford motorsports manual trans engine harness?
Old 04-18-2011, 01:13 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
Scroll down here and it says bell pattern is the same as 4.6:
Ford Racing Performance Parts
Old 04-18-2011, 02:06 PM
mark73899's Avatar
mark73899
I seen that,just was not sure if there would be any problems i should know about.
Old 04-18-2011, 10:27 PM
85e150's Avatar
85e150
Cost alone is a big enough "problem"....
Old 08-28-2011, 08:25 PM
piglett's Avatar
piglett
piglett is offline
well look guys if you want some coyotes to put in your truck just make your way up to my place in new hampshire. i hear them going yippp, yippp, yippp almost every night out in the fields. maybe you want a coyote in your truck as a theft deterant they have big teath & i would bet good money no one will dare climb into the cab of your truck.
come take all you want i'll even help you bait the traps
sorry i just couldn't help myself
good luck with your swap
piglett
Hackster1
741
09-21-2019 11:55 AM
klr
12-26-2016 07:53 PM
sstemy
2009 - 2014 F150
21
10-06-2016 08:03 AM
Kyler7700
12-26-2015 08:41 PM
1969 Bronco Coyote
Engine Swaps
19
08-26-2011 09:12 AM
Quick Reply: coyote with a zf 5-speed
