How to get rusted rim off hub? Need advise
I am trying to remove my right rim on my 95 E150 from the hub but it seems to be rusted in place. I tried:
1) Penetrating spray (still waiting for it to set fully)
2) Beating it with a rubber mallet
3) Wiggling it side to side (won't budge)
4) Prying it with a flatnose screw driver and only ended up breaking two good screwdrivers.
Any ideas on how to remove this rim?
The bigger hammer may work but I've had better luck with less damage by loosening wheel lugs and making a few tight turns in the back yard ( I've got a big back yard so if you don't, improvise).
I've had rims that I almost beat to pieces, heated up, tried everything and did loose wheel thing and they popped.
Good idea! I live on a cul d sac so driving in circles is no problem lol. How loose should the lugnuts be? Perhaps just hand tight? I will try this first thing in the morning if it does not work I'll go buy a big hammer and wood.
Nothing can happen by driving with one wheel that has fresh brake pads and other old ones right? As long as it's slow driving?
a few years ago in an 83 LTD, some person i won't mention installed a pair of rims from a FWD ford (same 4x4.25" bolt pattern, slightly smaller center hole), and i got to it in the spring when it was time to take off the studded tires. after trying the loose nuts trick, including abusive braking in both forward and reverse, and spending much effort with a BFH, it still hadn't budged. finally, i tore apart the rear axle, put the wheel/axle shaft assembly in the press, and just over 5 tons of force was required before the shafts popped out of the rims.
its good to hear you got it off without too much fight!!
I'm okay with these sorts of accidents-----only coz I'm in the auto glas biz!!
Might also be a good idea to lightly coat the back side of the wheels with anti-seize----some think that's over kill but it can't hurt.
Adding that removing all lugs except two on opposite sides then moving the van forward or backward just a touch before slamming on the brakes----assuming you don't have a convenient cul-de-sac or big back yard.
As far as how loose to leave the lugs I'd let just leave the very bottom of the lugs "touch" the wheel hole, not so much the wheel could **** on the studs, possibly bending them.
Hopefully this isn't a common problem but it can be a PITA when it happens.
maytea
06-01-2017 09:55 PM
