Radio removal on my 2003 truck
This is the tool it take to release the clips that hold it in.
You can make your own out of a coat-hanger.
New OEM Radio Stereo Release Tool/Tools Removal Key 2 | eBay
YouTube - Ford Car Stereo Removal and Others
I recommend the $2 tool(s), they are spring steel with ends that snap in place to the correct depth, with a coat hanger you'll be fishing around...but yeah it'll work if you have an idea how the clips are situated.
On the other hand, if you don't know how the clips are situated, you may not get them to work properly. I found it easier to disassemble my dashboard, and I needed to do some other things behind it anyway. Once I had the dashboard apart, it was easy to see how the clips were supposed to work. If you have never seen them before, never worked the tool, it may not work for you. Good luck.
Oside boy DIN is the normal size of a radio
DOUBLE DIN is the thickness of 2 radios
id suggest you pull ur radio out and if the back comes out a little bit then dips down then you will know you have a din and a half let me know if you have anymore questions and i can see some pics
MRCSUSN2007
01-10-2014 08:14 AM
PickSty
04-16-2004 10:07 PM
