EBPV gutting
Old 04-11-2011, 06:16 PM
smash fascism's Avatar
smash fascism
smash fascism is offline
EBPV gutting
After you remove the housing is there a gasket between the housing and the exhaust housing that I will need to replace? I have also read threads about gutting this and some show cutting of the pedisol. Just curious why this is being done? It shows some kind of actuator being removed from the pedistol.
Im going to be doing this mod this week and want to make sure I have all the parts I will need.
Thanks, Matt
Old 04-11-2011, 06:27 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
There is no gasket in there iirc. I did the pedestol mod on mine, I removed the actuator and the cylinder as you mentioned and welded the holes up. You can just remove the actuator and put a pipe plug in there but it's still hard to get to that one turbo bolt. Lots easier to remove/install turbo without that thing on there. It is aluminum so if you do it you need to know that. I'll see if I can find a link for you.
Old 04-11-2011, 06:28 PM
427 fordman
Old 04-11-2011, 06:32 PM
redman84's Avatar
redman84
redman84 is offline
I pulled the housing, cut out the valve, and plugged the hole. Three 12 point bolts holding it on IIRC. I want to do the pedestal as well but haven't had the desire to get in there and fight those dang bolts.
Old 04-11-2011, 07:28 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Exclamation
Thanks, Matt
IF you remove the pedestal, for sure you will need two of this o-rings for it:
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
(Ford) F4TZ-6N653-A & F4TZ-6N653-B
(International) 1815560C1 Turbo to pedistal O-ring .421 x .560
(International) 1815561C1 Turbo to pedistal O-ring .769 x .908
<o></o>
Old 04-11-2011, 07:36 PM
BuckHammer's Avatar
BuckHammer
BuckHammer is online now
What is the advantage of gutting the EBPV?
Old 04-11-2011, 08:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Less restriction (it blocks about a 20%), less EGTs.(20-50 IIRC) and if you mod the pedestal no oil leaks there in the rod and better work when unistall your turbo.
Old 04-12-2011, 12:27 PM
smash fascism
so there is no advantage other than easier turbo removal by cutting the actuator off correct?
Old 04-12-2011, 02:42 PM
427 fordman
not really, just sooo much easier to do the turbo and you don't have to worry about it leaking. Plugging it will not let it leak, but the turbo still sucks...
Old 04-12-2011, 06:41 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Well is not just cutting the actuator you have to mod the pedestal. Luck the pics below (stock and after mod).
X2 on that
E55 Bulldog
07-25-2020 03:01 PM
06F35089
1997 - 2003 F150
02-11-2017 08:55 AM
ranagent
01-03-2017 11:23 AM
Wodahs
07-26-2014 08:18 AM
Rollin.IH.Coal
03-22-2014 10:55 AM
Quick Reply: EBPV gutting
