EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Have you looked under the front of your 2011 EB yet?
Old 04-10-2011, 11:59 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
Here are some pics of the underside of my engine and tranny.
Not sure why all of this cover! Makes an oil change interesting, but actually fairly easy.
Old 04-11-2011, 11:17 AM
3bands's Avatar
3bands
3bands is offline
THe front of mine in front of that skid plate has a big plastic skid plate also that is in the way.
Old 04-11-2011, 08:12 PM
jimmyb08SD's Avatar
jimmyb08SD
Mine is a 4X2, any idea why all of these pans covering everything? Has to trap heat, but also keep out water!
Old 04-11-2011, 09:31 PM
djanzen's Avatar
djanzen
djanzen is offline
Fuel mileage! less wind resistance just like Nascar
Old 04-12-2011, 10:04 AM
dkf's Avatar
dkf
dkf is offline
Looks like it makes it a real PITA to work on from underneath. Would have been nice if Ford didn't tree clip the rubber to the pan so it is easier to remove. Those clips are basically a use once and throw away deal. Plates look too thin to block anything but small gravel and wind. So I agree djanzen. If you live in the snowy states it would probably be a good idea to pull the plates each spring for cleaning.
Old 04-12-2011, 07:33 PM
djanzen's Avatar
djanzen
djanzen is offline
it might be for wind noise reduction also?
Old 04-13-2011, 03:17 PM
sewhalen35's Avatar
sewhalen35
sewhalen35 is offline
It looks like there is a "flap" in the middle front of the plate. Is that so you can get to the oil filter?
Also, I've read in the 2009+ F150 forum that guys are having issues with water and mud getting into the alternator since it is mounted on the bottom front of the engine. Wonder if this was a fix for protecting the alternator???
Does all the EB have this? If not, wonder when they started addding it and if the earlier EBs will get a recall notice to have it added? Is it on the 5.0 or 6.2?
Old 04-20-2011, 09:20 AM
drh1175's Avatar
drh1175
drh1175 is offline
No kidding. I was looking under mine I figured out how to get to the Oil drain plug it is just behind the galvanized plate that is covered by the soft fiber one. Can you get to the filter through the galvanized door held by those clips? Wonder how long those will last?
Old 04-25-2011, 04:12 PM
jimmyb08SD's Avatar
jimmyb08SD
The filter is accessible through the rubber flap in the front of the metal pan, one side of the rubber is held in with the twist clips and opens right up to reach in and get the filter. There is also a built in drain tray which funnels the oil out to the front. Caution loosen the filter slowly and let it drain slowly, if you twist it off fast the tray will overflow and you have a real mess inside the pans! Other than that an oil change is fairly easy!
Old 04-25-2011, 06:47 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
I'm guessing the plates help with wind resistance for EPA mileage purposes, keep salt spray off the engine, trans, and associated parts to help avoid corrosion of steel parts, keep slush and ice water off the turbos, etc.
Looks like a nice job on Ford's part. I'm sure those plates cost a few bucks, so they would not put them on if there was not a good reason.
Edit--I remember reading that the EB turbos and exhaust system run hot, looked it up, and noted that max operating temp of the turbos is 1740 degrees F. Yes that's 1740 degrees. Imagine hitting those turbos and exhaust manifolds with a giant splash from a puddle of salty slush that is below freezing temp. This makes me think of the term "thermal shock"... Plus I can imagine setting a field of tall grass on fire pretty easily.
George
Old 04-25-2011, 10:25 PM
jimmyb08SD's Avatar
jimmyb08SD
Never thought of the whole grass fire thing!
I ran this thing at 70 mph for many hrs this past week (2200 miles, Pittsburgh, Pa and back to Florida) and the temp gauges were just fine, and absolutely no problem with cabin heat either. What a fun truck to drive!
Old 04-25-2011, 10:30 PM
jimmyb08SD's Avatar
jimmyb08SD
I gave her, her first oil change in Pittsburgh (DIY) before returning back to Florida.
GreatNorthWoods
21
10-10-2012 09:46 AM
duphofff
12-21-2011 05:49 AM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
cowmilker08
Indiana Chapter
04-14-2009 02:56 PM
08350
6.4L Power Stroke Diesel
04-22-2007 10:32 AM
Quick Reply: Have you looked under the front of your 2011 EB yet?
