Alright. Will replacing this fix my oil pressure gauge? The needle on my gauge is always showing completely low oil pressure. When i take off from a stop, it moves to about mid range and then goes right back to low.
Maybe. Just be aware that your OP gauge is not really a gauge, it's an idiot light. The sender is only an on-off switch that comes on at 7 psi. There is a resistor on the back of the gauge that makes it read in the "normal" range when grounded by the sender.
or just do the conversion and jump the wire on the back of your cluster and put a real OP sending unit in from say... a 85 302... There are tons of threads on here about how to do the conversion. then you get an actuall variable pressure reading on your stock cluster guage.
