1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 SWD vs F350SWD
Old 04-04-2011, 05:18 PM
Northbrook's Avatar
Northbrook
Northbrook is offline
F250 SWD vs F350SWD
I am thinking of getting a 5th wheel. Can be at a weight up to 16,000 pounds. 38 feet long. I have been told the F250 and F350 have the same engine. I would prefer a SWD vs Dually but not sure yet. My question is: What is the major difference betweem a F250 SWD and a F350 SWD?
Old 04-04-2011, 05:47 PM
acf6's Avatar
acf6
acf6 is offline
the major difference if you order both of them the same are door badges, 2.5" inch rear block on the 250 vs 4" on the 350 and 250 gvwr is 8800 while 350 gvwr is 9900.
everything you need to know and more about SDs
Old 04-04-2011, 05:53 PM
clem1226's Avatar
clem1226
clem1226 is offline
thats pretty heavy. How far and how often do you plan on pulling it?
to answer your question F350s and F250 are pretty much the same truck, the F350 has bigger blocks in the rear.
If I was going to pull 16K regularly I would want a dually for sure.......with a real deep rear 4:30 or do...
Old 04-04-2011, 06:13 PM
senix's Avatar
senix
senix is online now
Received 1,406 Likes on 1,002 Posts
newer trucks..F250 has a GVWR of 10K and over 11K on the F350. That is the door cert. Mechanically that has been answered above.
SRW F350 can do the job. Mine is a F250 and my 5er is 14 K and 40' long.
Old 04-06-2011, 08:30 AM
mrminvt's Avatar
mrminvt
mrminvt is offline
The one ton has an additional leaf spring in the rear suspension giving it the added weight capacity. I tow a fifth wheel with mine and it performs beautifully... I definitely recommend the 5th wheel over regular tow behind. I had a tow behind before I traded up to 5th wheel and it is a dream to drive. My truck is SWD and it does all I need and then some. No need to enter the dually realm in my opinion, you just get more truck which costs more to own over the life of the truck (think about the additional tires, lower mpg, possibly more money at the toll booths and higher yearly registration cost increases...) Unless it is a working truck that really needs the heavier capacity in an everyday way, the SRW should do the trick. The only downside to 5th wheel vs. tow behind is losing some/much of the space available to you in the bed while towing, and the inconvenience of the hitch attachment brackets in the bed the rest of the time.
Old 04-06-2011, 11:33 AM
78bigbronco's Avatar
78bigbronco
78bigbronco is offline
At 16k depending on how much hitch weight there is you might have to have a dually to be legal. Mechanically speaking no real difference though, and same spring packs available for both (overloads that are standard on the 350 come with any of the optional suspension packages on the 250 also).
Old 04-06-2011, 02:14 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Poor dead horse, he's gonna get another beating.... This has been researched by several folks.
There were a few rear spring packs used. Which was used depended ONLY on the body style and options specified on truck.
F250 versus F350 had nothing to do with it. A 250 ordered with the same equipment as a 350 appear to have gotten the exact same springs. Just a thicker block, a different rating on the door tag, and a higher price on the 350.
It is possible more
Old 04-06-2011, 02:27 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Back to the OP's question....
With that large of a 5'er, you will most likely need the ratings of the 350. Depending on the specific coach, possibly even need to get 350 DRW or 450 to be within legal ratings (if that matters to you). Especially if you haul passengers and stuff in the truck bed (like an auxiliary fuel tank or firewood, which is surprisingly heavy). Some coaches have a LOT of pin weight.
I assume you already know that published axle and pin weights of RV's are almost always blatant marketing lies?
I ALWAYS recommend insisting on getting new RV's actually weighed before signing the bottom line. 10-20% over published axle and/or pin weights is not uncommon. And once you load up your things, it gets only uglier.
Buy right, buy once, enjoy the ride!
6.2L V8
13
06-06-2017 08:59 PM
Sleepyguy
2017+ Super Duty
01-27-2017 11:39 PM
TenTex
2017+ Super Duty
12-24-2016 12:39 AM
Turrentine14
03-06-2016 03:52 PM
3wheeler
01-13-2008 12:26 AM
Quick Reply: F250 SWD vs F350SWD
