ford 6.6L
Old 03-31-2011, 11:14 PM
bigdually3's Avatar
bigdually3
bigdually3 is offline
ford 6.6L
im in athens georgia and im looking to swap a 6.6L into my 84 f350. wheres the best place to look for an engine and trans setup for my truck?
also what transmission options do i have for the 6.6L. id like to keep it automatic.
also just to be stupid clear i am talking the ford 6.6 diesel inline six
Old 01-20-2013, 11:01 AM
Doug Burton's Avatar
Doug Burton
Doug Burton is offline
I have a Ford 6.6 inline 6 cy diesel i just bought this dump truck with this engine in it I need to bleed the fuel system where is the primer pump and what does it look like.And where could i get a service manual for this engine thanks
Old 01-20-2013, 11:10 AM
Doug Burton
hi my mane is Doud i just bought a truck with this engine in it and dont know nothing about it i need to bleed the fuel line do you know were the fuel primmer is and what dors it look like thanks for your help ldbnab@gmail.com thanks Doug Burton
Old 01-08-2017, 10:32 AM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
We had a fleet of 6.6's back in 89. The primer pump if I remember is on the right side of the block mounted on the transfer pump. It has an obvious **** on it that you unscrew to allow it to pop up. Ours had Allison AT 545 transmissions. These engines were solid with the only issue being the head gasket would leak coolant after a few years.
Bigtruckman66
New Member Introductions
01-16-2018 11:06 AM
knucklecars
07-30-2016 03:28 PM
rogbash
06-14-2016 08:59 AM
eyyu
04-19-2016 10:41 AM
jmf66
13
04-13-2016 08:49 PM
Quick Reply: ford 6.6L
