2007 Expedition EL Limited - Rev/speed limiter?
Old 03-31-2011, 10:45 AM
SickPup404's Avatar
SickPup404
SickPup404 is offline
Can anyone point me towards any resources (if available) to disable/bypass the rev/speed limiter? Was surprised that it "throws out the anchor" at 100 MPH....
Old 04-04-2011, 01:41 AM
st381's Avatar
st381
st381 is offline
Why on earth would you need to take a Expedition over 100MPH??
Old 04-04-2011, 04:59 AM
SickPup404's Avatar
SickPup404
Because I don't like government or corporations telling me I CAN'T.
Old 04-04-2011, 06:35 AM
ExpyBob's Avatar
ExpyBob
ExpyBob is offline
My 2007 cut out at 103MPH. My 2011 is similar. I'm not sure if it's a rpm limiter or speed limit (limit). Didn't have the time to look down that long to see.
Old 04-04-2011, 02:35 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
Try to find a set of 44" mudder tires... the huge circumfrence will full the speed limiter into thinking you're only going 100 when its actually going 120 or so!
Old 04-05-2011, 03:32 PM
function12's Avatar
function12
function12 is offline
I would check the speed rating of your tires too. Bad things happen when tire disassemble.
Old 04-05-2011, 05:08 PM
SickPup404's Avatar
SickPup404
Good point! I had to put four new tires on in the fall - Michelin LTX M/S2. They were almost $1400 installed (with an aligment). Pretty good T rating on them at 118 MPH. Still nowhere near the tires I had on my old sport sedan!
Old 04-06-2011, 06:35 AM
T.A.'s Avatar
T.A.
T.A. is offline
Well that's a great reason to take a 6000+ lb brick over 100
Old 04-06-2011, 08:00 AM
gpfarrell's Avatar
gpfarrell
Frankly, if you want to go over 100mph you might have done better to put that $1400 towards an old BMW sport sedan. While likely exhausted at this point, at least it was initially designed to hit those speeds.
Buying a 2007 BMW 750iL (what are they now, about $40,000 used?) and expecting it to tow your 8,000 lb boat, haul firewood through the woods, or carry 8 people in its 5 seats would be no less ridiculous than pushing your Expy faster.
I like speed as much as the next guy, but you need a different set of car keys.
Old 04-06-2011, 10:30 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
I could not agree more.
Old 04-06-2011, 11:19 AM
berry1234's Avatar
berry1234
berry1234 is offline
If your not a troll, then you are either 14 or just very immature, either way move to Germany.
Old 04-06-2011, 09:00 PM
SickPup404's Avatar
SickPup404
All points well taken, thx for the advice. (Though I'm a long way from 14, I'll admit to immaturity at times! )
Old 04-23-2011, 12:35 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
It's good enough to make me want to take my 8000 lb truck over 100 mph
nextalcupfan
38
01-28-2020 06:18 PM
llwizzoll
New Member Introductions
02-13-2007 09:40 AM
MustangGT221
16
03-22-2004 01:24 PM
stover007
Modular V8 (4.6L, 5.4L)
05-16-2003 10:29 AM
4x4x4x4
Modular V10 (6.8l)
17
04-17-2002 11:45 AM
Quick Reply: 2007 Expedition EL Limited - Rev/speed limiter?
