1970 4x4 Crew Cab
Old 08-05-2008, 06:32 PM
garbz2's Avatar
garbz2
garbz2 is offline
I get 8 if i keep it at 55.
If i run side streets at 45 i can get around 14.
Nice Crew. I have a 472EFI with a C6 setting for my crew, Need to get the 63 going first then the crew will get redone. I picked up mine with only 46k original miles here in Arizona.
Garbz
Old 08-16-2008, 08:15 PM
maddog crew 360's Avatar
maddog crew 360
maddog crew 360 is offline
hey guys gears???????
i think that my truck has 456's because the guy i am buying it from told me that i could pretty much start out in third if i wanted to
now i dont want to redoo my gears to be able to get a better rpm rang so i am just going to put on bigger tires. i was just wondering if you knew of anywhere i could get a 4-6 inch susp lift for a good price????
oh i was just wondering how rare the original 1970 ford factory winch is???
Old 08-22-2008, 12:08 PM
iggybob44's Avatar
iggybob44
iggybob44 is offline
Are you certain the winch is a factory item? I know Jeep,IH,and Dodge Had factory PTO winches,IH used mostly Ramsey,Dodge used mostly Braden,and Ive seen Ramsey and Koenig on older jeeps. What brand winch do you have? BTW, the money you spend on bigger tires/wheels,and a suspension lift would likely buy a whole lot of gas! Have fun with it,but no matter what you do with a truck like this(short of putting in a diesel), your mileage is going to be poor
Old 08-22-2008, 12:28 PM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
i get 11 if i keep it at 55mph, with 3.73s out back, a C6, and 33 inch tires - the best way to get better MPG is to get an over drive for your truck.
Old 08-23-2008, 10:29 AM
maddog crew 360
i found out that i have 411's rear and 409's front
ya i found that out last night and as for the deisel i was already planning on puting in a 5.9 cummins in the future. also found out that my motor is from a 76 f250 but still the same. it has elec ignition but still want some more ignition upgrds but runs not to bad. seems like i loose alot of power in 3rd gear. as for you guys with the front end probs when you go fast ... i was going 72 and there was not a single vibration or anything.
Old 08-23-2008, 10:32 AM
maddog crew 360
oh and im almost positive but i havent took a real close look yet
664x4drvr
11-11-2017 02:27 PM
low-blow00
21
08-25-2015 08:43 PM
Ravenwood Ranch
Car/truck Buying Advice
01-29-2015 06:27 AM
kaw753
WTB - Ford Trucks & other vehicles
07-27-2012 01:29 PM
The Freak
23
11-02-2009 07:34 PM
Quick Reply: 1970 4x4 Crew Cab
