237/75/15 vs 9.5x30/15???
Old 03-21-2011, 09:11 AM
IowanStraight6's Avatar
IowanStraight6
IowanStraight6 is offline
Question 237/75/15 vs 9.5x30/15???
ok thinlin about new tires on the 96 f150 (STOCK HEIGHT) and read that the 9.5 wont rub on lock but how much bigger are they anyone with pics?? how much would my speedometer and gear ratio be off (3.55 now) and how much should my milage drop also i pull car trailer regularly will i notice a losse in power??
Old 03-21-2011, 09:33 AM
Conanski's Avatar
Conanski
Conanski is offline
The 30x9.5 tires are about an inch taller than 235s, that will make the speedo read 2-3mph slower and it will hurt power a little but not a whole lot. See my Album for pics of my truck with 30's on it.
Old 03-21-2011, 02:07 PM
IowanStraight6
you notice much on power
Old 03-21-2011, 04:37 PM
Sgt Neutron's Avatar
Sgt Neutron
Sgt Neutron is offline
Plug in your tire sizes into this calculator and it'll give you a bunch of comparisions:
Tire Size Calculator - tire & wheel plus sizing
Old 03-21-2011, 05:09 PM
homesplat's Avatar
homesplat
homesplat is offline
How would a change in tire size reduce power? and also on that tire calculating site the guy before me posted it says that changing the tire diameter by more than 3% could result in brake failure.. why?
Old 03-21-2011, 09:37 PM
Conanski's Avatar
Conanski
Conanski is offline
Tires are part of the driveline and tire size factors into your final drive ratio. Without changing anything else the larger the tire the higher(numerically lower) your final drive ratio is. As an example if your truck has 3.55 gears going from stock to 30" tires changes the effective final drive ratio to 3.28, 31's makes it 3.18, 33's make it 3.0, 35's make it 2.82.
The tire size change won't affect engine HP but the taller gearing will make it seem like it lost power, it actually does reduce the amount of torque reaching the ground so acceleration will be slower.
The brake failure warning is a bit overblown but larger tires do put more leverage on the brake components and it will make them less effective.. though like everything else the amount of braking power lost is proportional to how much larger than stock the tires are. In the big scheme of things you probably won't notice much difference.
13nparthemore
Offroad & 4x4
03-03-2013 06:32 PM
95e150CW
58
06-17-2012 09:16 AM
sju96ford
17
06-20-2011 07:53 AM
roadrash63
Performance & General Engine Building
07-19-2010 05:34 PM
Wengnutt
03-30-2005 06:04 PM
Quick Reply: 237/75/15 vs 9.5x30/15???
