Hard Starting 6.0L - What the Dealer Did...
Old 03-16-2011, 09:34 PM
2000V10USER's Avatar
2000V10USER
2000V10USER is offline
Just following up on an item for a friend. He has a 2005 F250 with the 6.0 Diesel. Over the past month it has been progressively harder to start when it was warm. (starts fine in the morning or at the end of the day when it was cold) He took it to the dealer and they diagnosed it as low oil pressure with the corrective action being the replacement of the high pressure oil pump. Long story short (and $1600 later) when he got the truck back it was doing better but still seemed not right. Bled air from the fuel system and all seems okay. Has anyone else had this "Bad High Pressure Oil Pump" diagnosis? Seems a little strange but I can say I am an expert (I have a 2000 F250 w/V10).
Old 03-17-2011, 12:20 AM
donovan's Avatar
donovan
donovan is offline
common
one of the common issuse for the 6.0.
Old 03-17-2011, 08:07 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
RCKYMTN-PSD is offline
Post this down on the 6.0 section for some answers. harder starting only when its warm is not normal
Old 03-17-2011, 08:48 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Powerstroke Diesel forum.
Old 03-17-2011, 09:02 AM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
I didn't know the HPOP itself was a common issue? The STC fitting on the 05's HPOP was a common issue though.
Old 03-17-2011, 04:12 PM
donovan's Avatar
donovan
donovan is offline
HPOP
The HPOP has been a problem, and so has the fitting that holds the oil line in place. It is not as common as the EGR Cooler. STC fitting how many times did ford revisit that one.
Old 03-17-2011, 05:21 PM
cheezit's Avatar
cheezit
cheezit is offline
hmm we dont do many 05+ up pumps at all.
Old 03-17-2011, 06:21 PM
rollerstud98
were the 03 and 04 HPOP's problematic cheezit? I'm still running the original on my truck with 263k km's on it, early 03.
Old 03-17-2011, 06:22 PM
cheezit's Avatar
cheezit
cheezit is offline
we see more of them then the later style thats for sure. still not many of them either.
Old 03-18-2011, 06:24 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
A LOT of HPOP's are replaced unnecessarily simply because of the STC fitting failure and incorrect diagnosis OR a tech too lazy to properly diagnosis the problem. I've never seen any discussion that the later HPOP's were a problem....more like virtually bulletproof.
Old 03-18-2011, 09:15 AM
dirtleg's Avatar
dirtleg
dirtleg is offline
No one has mentioned the oil rail plugs. That was my problem with hard warm starts. $45 later and a few hours of work good to go.
Old 03-18-2011, 10:16 AM
High Binder's Avatar
High Binder
High Binder is offline
Did you just replace the plugs?
Old 03-18-2011, 05:33 PM
cheezit's Avatar
cheezit
cheezit is offline
you can nolonger get just the o-rings. so yes you most replace the plugs.
Old 03-18-2011, 07:00 PM
tharepairguy's Avatar
tharepairguy
tharepairguy is offline
Found that out yesterday, $106 later.
M1911
04-22-2016 07:54 PM
Chase Meyer
04-06-2016 11:55 PM
hondamanex400
04-01-2016 10:47 PM
mintons5
09-08-2011 09:07 AM
WHITE F350
01-15-2007 02:08 PM
Quick Reply: Hard Starting 6.0L - What the Dealer Did...
