Max tow package vs regular tow package??
Old 03-11-2011, 06:35 PM
Lockon's Avatar
Lockon
Lockon is offline
In the 2011 models the only difference I could find between the regular tow package vs "max tow package" was the tow mirrors, brake controller, and an "upgraded rear bumper." Could I presume that if I added the brake controller to the "regular" tow package I could tow the same amount (lbs wise) as if I have the "max tow package?"
Old 03-11-2011, 07:29 PM
efx4's Avatar
efx4
efx4 is offline
I have the tow package (like all FX4's) with the options being the TBC, but I put the tow mirrors on myself. I looked on Fords site but couldn't determine what the difference is either. I've heard someone say on here that a 4:10 rear MAY be the part of the max tow pkg., I'm sure someone will chime in with some better info.
Old 03-11-2011, 11:00 PM
n578md's Avatar
n578md
n578md is offline
TRAILER TOW PACKAGE (535)
Usage: Required for towing over 5,000 lbs.
Availability:
• Standard on FX2/FX4 and Lariat
• Optional on XL, STX and XLT
Includes:
• Class IV trailer hitch receiver
• 7-pin wiring harness
• Upgraded radiator
• Auxiliary transmission oil cooler
• SelectShift Transmission
MAX TRAILER TOW PACKAGE – MANUAL MIRROR (60M)
Availability:
• Optional on XL Regular and SuperCab
Not Available with:
• 126" wheelbase
• Power Equipment Group (85A)
• Max Trailer Tow Package (60P)
Requires:
• 3.5L EcoBoost™ Engine (99T)
• 3.73 LS rear-axle ratio
• Heavy-Duty Payload Pkg. (627)
• XL requires Fog Lamps (595) with XL Décor Group (86D)
Includes:
• Upgraded rear bumper
• Upgraded radiator
• Trailer Brake Control
• Side mirrors, black manual telescoping trailer tow w/manual glass
MAX TRAILER TOW PACKAGE – POWER MIRROR (60P)
Availability:
• Optional on XL Regular and SuperCab, XLT and FX2/FX4
Not Available with:
• 126" wheelbase
• Max Trailer Tow Package (60M)
• XLT SuperCab 145" wheelbase with P235/75R17 BSW A/T (T7B),
L245/75R17E BSW A/T (T7E) or P255/65R17 OWL A/S (T73)
• XLT SuperCrew with P255/65R17 OWL A/S (T73) or L245/75R17E
BSW A/T (T7E)
Requires:
• 3.73 LS rear-axle ratio (XL, XLT and FX2)
• 3.73 electronic-locking differential axle (XLT w/Off-Road Pkg. – 55A and
FX4)
• XL requires Fog Lamps (595), XL Décor Group (86D) and Power
• XL and XLT Regular Cab requires Heavy-Duty Payload Pkg. (627)
Includes:
• Upgraded radiator
• Side Mirrors, black manual telescoping trailer tow w/power glass
(includes heat, turn signal & puddle lamps)
• Memory feature included on side mirrors when order with FX Luxury
Package (55F)
MAX TRAILER TOW PACKAGE – POWER, CHROME
MIRROR (60C)
Availability:
• Optional on Lariat, King Ranch® and Platinum
Requires:
• 3.5L EcoBoost™ Engine (99T) or 6.2L V8 (996)
• 6.2L V8 on Lariat and Platinum also requires SuperCrew 145" WB
• 3.73 electronic-locking differential axle (Lariat or King Ranch® w/Off-
Road Pkg. – 55A)
Includes:
• Upgraded radiator
• Side Mirrors, Manual Telescoping Trailer Tow w/Power Glass (includes
heat, memory, turn signal & puddle lamps & Chrome Skull Caps)
Old 03-12-2011, 09:53 AM
B W Smith's Avatar
B W Smith
B W Smith is offline
In Ontario Canada we have to order the towing mirrors as an extra. The Max Tow comes with upgraded rad, oil cooler, rear springs and bushing mounts, steering gear, brake controller and 3:73 rear gears. It has the upgraded bumper and 7-Pin wiring harness. You must get the Ecoboost. Crazy thing about it is the price. With discounts the "Max Tow" is cheaper than the regular tow package.
Old 03-12-2011, 01:00 PM
mrpositraction's Avatar
mrpositraction
mrpositraction is offline
Still confused!
I have an FX4, are the only things I am missing is the trailerbrake controller and the telescoping mirrors?
Old 03-12-2011, 04:19 PM
efx4's Avatar
efx4
efx4 is offline
Originally Posted by mrpositraction
Still confused!
For the most part. Max tow I'm sure is nice to have, but the tow pkg. is all most will ever need, myself included.
Old 03-12-2011, 06:28 PM
rb48f6's Avatar
rb48f6
rb48f6 is offline
A nice feature is the telescoping mirrors, had them on my SD and a few inches further out makes a big difference in seeing farther back. I'll just look for add-ons or something for the powerfolds on the FX4, and use as required. I don't pull every day.
Old 03-13-2011, 07:25 AM
spdmpo's Avatar
spdmpo
spdmpo is offline
I didn't get max tow because I don't want the required 3.73 gearing. I will miss those pull out mirrors like I also had on the super doodie. If I find I need them later I'll add them.
Old 03-13-2011, 07:39 AM
bigal1234's Avatar
bigal1234
bigal1234 is offline
My understanding is that if you want to tow more than a 5000 lb trailer you need the max tow package. Period.
Al
Old 03-13-2011, 08:55 AM
efx4's Avatar
efx4
efx4 is offline
The tow package enables the truck to tow up to the tow rating of the truck, and the Max Tow enables towing at the maximum tow rating. On my truck the tow rating is 9,500#, but if I had the Max Tow Pkg., it would be 11,100#. I've been RV'ing for 11 years using F150's and bought only trailers well with in the tow weights of the trucks, and have been fine with all of them.Since a Super Duty is way more truck than I need, the F150's with the tow pkg. have been working out fine, these trucks handle trailers surprisingly well.
Old 03-13-2011, 09:41 AM
spdmpo's Avatar
spdmpo
spdmpo is offline
Al
Then you do not understand correctly. Period.
Old 03-13-2011, 05:24 PM
daveo987's Avatar
daveo987
daveo987 is offline
Al
Thats not true, I got an 011 3.5l SC XLT with 535 tow package, rated for 8,600 maximum tow weight. I could NOT get Max tow/627 package on the SHORTBED. Could of if it was the Longbed.
Old 03-13-2011, 05:39 PM
bigal1234's Avatar
bigal1234
I stand corrected. Sorry for confusion. I'm getting a sc with 8 foot box.
8200lb payload, 11200 lb tow.
Al
Old 03-13-2011, 10:45 PM
81beast's Avatar
81beast
81beast is offline
Max tow is required on the FX4 to get the 4.10 gears, as is the Ecoboost and 20" wheels. A truck with 3.73s can still get the Max Tow package by itself.
I just got my 2011 FX4 supercab with this configuration. The 4.10s are very low. I can't wait to get my 275/65R20 Nittos on to replace the factory Pirelli's. Also very anxious to get a trailer behind it.
Old 03-16-2011, 06:18 PM
TrapperDave's Avatar
TrapperDave
TrapperDave is offline
The telescoping mirrors are really awesome when backing up a trailer. And, makes my truck look an awful lot like Dumbo the elephant.
Quick Reply: Max tow package vs regular tow package??
