Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Another bedliner question
Old 03-08-2011, 07:37 PM
Rancheroracer's Avatar
Rancheroracer
Rancheroracer is offline
I'd like your guys opinion, I have an Ecoboost coming any day now & had just about decided on spray-in but after reading about dual liner not sure now. Which one would you recommend if you're hauling a lot of firewood? I'd like to prevent the dents to the wheel wells & floor as much as possible.
Old 03-09-2011, 11:09 AM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Have you considered a BedRug?
Old 03-09-2011, 11:59 AM
Rancheroracer
From what others have told me about it, small stuff from the firewood hauling would be difficult to remove, like pine needles, etc.
Old 03-09-2011, 02:23 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Well you couldn't sweep it out easily but a vacuum or pressure washer would work just fine.
The upside is your bed will still be like new.
Old 04-26-2011, 12:03 PM
darrelf150's Avatar
darrelf150
darrelf150 is offline
The Dual Liner is the way to go! I haul bricks, C blocks, compactors, and scaffold Dual Liner has the best dent protection for those critical areas (the floor and the wheel wells). I would destroy a spray on in less than a year. I have had the dual liners for several years and they still look great and do there job well. I like that I can take the Dual Liner out to clean the truck too. The Dual Liner bed liner is the best bed liner I have ever owned!
Old 04-26-2011, 12:17 PM
Rancheroracer
Does it fit to the sides & corners real close? One thing I don't care for on the one piece liners is the way they aren't close-fitting, esp. in the corners. I hate to lose that little bit of space, (I haul my dirt bikes & the 6.5 bed is really too short the way it is). Makes the difference in whether I can close the tailgate or not.
Old 04-26-2011, 12:41 PM
darrelf150's Avatar
darrelf150
It fits tight to the sheet metal, so no wasted space what so ever. This Dual Liner installation video shows it really good Bed Liner Installation - Bedliner Installation Videos
Old 04-26-2011, 01:10 PM
Rancheroracer
Thanks, I think that's the way I'll go.
Old 05-07-2011, 10:45 PM
egbertnr's Avatar
egbertnr
egbertnr is offline
Add Dual Liner to my list of liners to compare when I get my truck
Old 05-08-2011, 01:00 AM
Rancheroracer
I just put one in my truck & I'm satisfied with it. Good fit as claimed & doesn't take up wasted space in the corners like the one-piece units I've had.
Old 05-10-2011, 02:10 PM
Freyja's Avatar
Freyja
Freyja is offline
Ask a dealer for a BedRug sample, and get it dirty. Then see how easy it is to hose/sweep off.
Made me decide to go with a Spray in.
Old 05-10-2011, 02:32 PM
TruckDaddy's Avatar
TruckDaddy
TruckDaddy is offline
Most spray-ins are tough and if you get the right one, is WAY nicer looking than a gray rug or plastic/rubber combo.
Old 06-10-2011, 10:38 PM
lakedweller's Avatar
lakedweller
lakedweller is offline
Use a trailer, problem solved .... You are welcome....
Old 06-28-2011, 09:10 PM
egbertnr's Avatar
egbertnr
egbertnr is offline
installed my Dual Liner today, nice combo, couple things I would add are using bolts to tie down the lower half of the tailgate cover(tailgate step owners can ignore), I will be using rivnuts and bolting that section down, could fit just a little tighter up front, but all in all will fit my needs great. Rubber mat is sticky, aint nothing sliding around back there.
Will install an Extang Fulltilt tomorrow after work.
kailor
25
08-14-2011 02:05 AM
frdrngrlvr
Mid-West Region
12-08-2005 08:39 PM
RKNRL
1978 - 1996 Big Bronco
18
07-27-2005 09:16 AM
Mtruck96
03-19-2000 12:22 PM
Quick Reply: Another bedliner question
