BUYING A NEW 08 limited! need OASIS
Old 03-07-2011, 10:23 AM
thefnswits's Avatar
thefnswits
thefnswits is offline
hey all, i need an oasis on an 08 limited im about to buy (today maybe) vin is:
1FMFU20578LA88055
also, I need to know what kind of gears are in this...does it have the trailer tow package? any help is AMAZINGLY appreciated, thanks!
also if i dont get that theres an eddie bauer im looking at the VIN is
1FMFU185X8LA15549
any info on either would be amazing, the MAzda dealership doesnt really know what it has. THANKS!
Old 03-07-2011, 04:51 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
08 Limited = 3.31 gears, NO HD towing package, 18" wheels, reverse camera, power running boards. Built 9/12/08
08 Eddie Bauer = 3.31 gears, DOES have HD towing pkg, 20" wheels, NO reverse camera or power running boards. Built 8/25/07
If it were me I would go for the Limited because it has the newer redesigned heads that dont have the spark plug problems and it has just about everything except HD towing and 20's.
HTH
Matt
Old 03-07-2011, 05:25 PM
thefnswits's Avatar
thefnswits
Newer head was all I needed to hear! Ill be upfitting the limited for hd towing myself and will have to deal with 3.31s!
Old 03-10-2011, 06:45 PM
chuck s's Avatar
chuck s
chuck s is offline
A limited with $8000 worth of toys added. Window Sticker
-- Chuck
Old 03-10-2011, 07:18 PM
thefnswits's Avatar
thefnswits
I know, I got her!;-) what a beast! Shame that 50k dollar truck has chrome hubcaps though. I wanted to cry when I noticed that.
Old 03-16-2011, 06:18 PM
ridehog's Avatar
ridehog
ridehog is offline
Question about heads
HTH
Matt
Matt- I have a 2008 Exp Ltd I bought a couple of months ago. How can I tell if it has the redesigned heads and what was/is the spark plug problem? Do I need to be on the lookout for fouled plugs etc? It has 44,500 on it. Thanks.
Old 03-16-2011, 06:38 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
You need to know the build date. Post the VIN or look on the drivers side valve cover, it should have a date on the sticker. I believe you are looking for a date after late October 08. The sticker on the door jamb will at least give you the build month.
The problem with the plugs was that they could break off when removing them, leaving part in the motor. Redesigned heads had more threads and different plugs, supposedly solving the broken spark plug issue.
44,500 is a little early to swap plugs IMHO.
Just an FYI, I also have a 06 F150 with over 192,000 on it and it's on it's 3rd set of plugs. None have broken. First change was scary but second change was alot easier.
Matt
Old 03-16-2011, 07:08 PM
ridehog's Avatar
ridehog
ridehog is offline
Matt, thanks for the reply.... The VIN is: 1FMFU20598LA43117 Any info appreciated. Hopefully I don't need to get out the PB Blaster to change the plugs on the this...
Old 03-17-2011, 05:31 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Looks like you should be all right, late November build. 11/29/07
HD Tow Pkg, Rear Camera, Nav, Power Liftgate, RSE, 20's......
Pretty much loaded Expy. Love the White Sand Tri-Coat, that was my second choice.
Matt
Old 03-17-2011, 05:04 PM
ridehog's Avatar
ridehog
ridehog is offline
Thanks Matt. Appreciate the information.
Old 03-17-2011, 05:14 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
How often do you need to change the spark plugs? unfortunantly my 07 expy was built in 2/07
Old 03-17-2011, 05:51 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
coming to think of it my expedition has been mis firing on start up sometimes. is this a sign that i need new spark plugs?
Old 03-17-2011, 07:28 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Could be plugs or it could be coils. On my 06 150 it would misfire after shifting into overdrive about 45-50 mph and feathering the throttle. It was almost like riding a bucking bronco
Matt
Tomcat71
1999 to 2016 Super Duty
06-09-2015 05:54 AM
ericg70
2004 - 2008 F150
08-01-2014 03:21 PM
Virago6
01-06-2010 08:32 PM
scottman70
06-21-2008 05:47 PM
dr:cafe
04-06-2008 07:14 PM
Quick Reply: BUYING A NEW 08 limited! need OASIS
