Colorado Chapter Join Chapter, Leader:
Emissions on a F350
Old 03-07-2011, 09:51 AM
Fordby4's Avatar
Fordby4
Fordby4 is offline
Emissions on a F350
Ok,
So Larimer county decided to start the emissions program up here to generate some revenue, I talked with a Emissions tech, he mention that all I would need is a smog pump for this vehicle since it is over the 8500 gvw. I don't have any info on where to install and what is needed, can anyone point me in the right direction?
Dan
Old 03-08-2011, 08:42 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
Originally Posted by Fordby4
Ok,
Dan
what year truck and what engine is it?
Old 03-08-2011, 08:57 AM
Fordby4's Avatar
Fordby4
Fordby4 is offline
emissions
It's a 1979 Ford F350 with a 400 engine
Old 03-08-2011, 09:08 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
OK, I am not able to help you as I am not familiar with that engine and hear. However, I don't think not having a smog pump will cause you to fail the test due to emissions. It's probably what they call a 'visual fail' meaning that there are things that can cause you to fail the test based on visual inspection (not having a working check engine light is also a visual fail). The tolerances for the smog test they do here in CO are pretty high, they are really looking for gross polluters and I am not sure a pump will make a huge diff.
So, you may be able to pass the actual test if you can find someone to look the other way about the pump, not that I am advocating that
Old 03-08-2011, 09:29 AM
Fordby4's Avatar
Fordby4
Fordby4 is offline
emissions
I agree that they would fail it on a visual inspection, I am just trying to find out what was stock on this vehicle, because thats what there going to be looking at
Thanks for the feedback
Old 03-08-2011, 11:01 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Does the driver's side valve cover have a sticker on it? It should list the engine size and smog equipment that was put on at the factory. If that sticker is missing, the vehicle is held to the highest standard for that model year.
I'll keep an eye out for a '79 when I hit the boneyard.
Old 03-08-2011, 11:06 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Not gonna happen, you can't tip enough to offset the loss of revenue.
Old 03-08-2011, 11:10 PM
Fordby4's Avatar
Fordby4
Fordby4 is offline
emissions
I know the original motor on this truck was a 351, it has a 400 now, it came that why when I bought it
Old 03-09-2011, 07:01 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
Does it have the sticker on the VC?
Old 03-09-2011, 07:20 AM
Fordby4's Avatar
Fordby4
Fordby4 is offline
emissions
No sticker found on the valve cover
Old 03-09-2011, 07:15 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yeah, I might be able to help ya
I have this engine in my 1981, I'll try and take some pictures this weekend to explain more.
For the time being, do you have the check valve in your intake manifold? Probably not, I'm
guessing there's a pipe plug or something in that hole. This is to where the smog pump is
connected.
The pump itself is mounted on a bracket above the alternator, RH side of engine.
Old 03-09-2011, 09:38 PM
Fordby4's Avatar
Fordby4
Fordby4 is offline
emissions
Dude, that picture is disturbing,
I will look tonight
Old 03-09-2011, 10:16 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 03-12-2011, 02:56 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Here ya go
OK, I had this exact problem when I bought my 1981 with the same engine....
You should have a bracket that holds the thing as well as a smaller one in back, here are
mine:
Go to a junkyard and get yourself a smog pump, here's what I ended up with:
It installs mainly on the bigger bracket, the one in back is just to hold it in place. The belt
(not installed here) attaches to a pulley on the alternator, the hose connects to the check
valve that screws into the intake manifold (pic in earlier post):
You have a non-catalyst F350 so this pump doesn't really do anything useful but it's still
required that it be there.
BTW these are Federal laws....
Clean Air Act | US EPA
Transportation and Air Quality | US EPA
http://www.epa.gov/oms/regs/fuels/cff/memo-1a.txt
Old 03-18-2011, 02:22 AM
HeeHaw78's Avatar
HeeHaw78
HeeHaw78 is offline
i had the same problem with an 86 i had that had a 460 in it. i found the smog stuff at a junkyard for 50 bones for the whole setup, bought that and installed it. if you arent sure where to run a hose or something just run it to where it looks like it hooks up to something and that will usually do. i had to get mine tested in golden and they passed it there. luckily i now live in GJ where they dont have that crap yet but im sure its a coming sometime.
Lincolnman73
01-26-2014 05:32 PM
homerj
05-17-2012 03:17 PM
ClemsonExcursion
09-18-2007 07:01 AM
DarkWolf40
Colorado Chapter
05-07-2005 08:27 AM
o0haco0o
13
02-20-2004 03:13 PM
Quick Reply: Emissions on a F350
