Brake fitting pressure rating?
I couldn't find this anywhere else...does anyone know what pressure brake (inverted flare) fittings are rated for, especially brass ones?
I'm trying to cobble together an injector pop tester for my truck's injectors and I don't have a good way to connect the injector line to the rest of the pipe fittings I'm using. The line is 1/4" so I wondered if I could put a 1/4" tube nut on there, flare the line and use an inverted flare to pipe thread fitting.
Max pressure on the system should be 2000 psi or less, I don't know what kind of pressure brake systems can generate, that's why I ask.
Did a quick search on "brake line pressure" -- several places talked about 'upwards of 2000 psi'.
Here's a note from some premium replacements for the rubber hose segments -- they test to 3000 psi
Goodridge G-Stop Brakeline Kit.
Sounds like it will work, but it might be worth putting some shields in place to avoid any chance of injury.
Good Luck,
hj
Good Luck,
hj
underthebridgejim
17
02-17-2016 10:34 AM
flatheadshoals
11-30-2015 01:34 PM
Spparky82
08-19-2015 02:40 PM
ronspolv
02-05-2015 11:32 PM
