1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
87 Ignition Control Module screws
Old 02-28-2011, 10:33 PM
Thatmetal's Avatar
Thatmetal
Thatmetal is offline
What Kind of screws are holding the ICM to teh distributor on the 2.9 ? Phillips torx etc?
Old 03-01-2011, 05:47 AM
wp120470's Avatar
wp120470
wp120470 is offline
Not for sure how far back but we used the little ignition wrench i think it was a 5.5mm. They still see them at most parts stores if that is what you have.
Old 03-01-2011, 08:20 AM
tomw's Avatar
tomw
tomw is offline
They are hex head for sure, not Torkx nor Phillips head. The 'socket' body has a very thin sidewall to be able to slip into the hole in the TFI. The "Help" section as some parts stores carry the wrench, with a built-in **** style handle. If you do replace the TFI, make sure to use the heat sink compound, and be careful when you remove and install to move the TFI vertically from the bowl of the distributor. There are connections on the top of the TFI that poke up into a connector on the bottom of the bowl, and the connections can get real wobbly if the internal pickup has gotten rubbery due to age or oil or heat... You CAN get the connectors to work without replacing the internal pickup if you are very careful.
tom
Old 03-01-2011, 02:36 PM
Thatmetal's Avatar
Thatmetal
The wrench is an alan wrench right?
Old 03-02-2011, 06:36 AM
wp120470's Avatar
wp120470
wp120470 is offline
No its like a **** with a thin wall hex head. Go to your parts store and ask them for a Ford Ignition Module Wrench. It should cost around 5 or 6 bucks.
Old 09-19-2015, 10:02 AM
Chasm*18's Avatar
Chasm*18
Chasm*18 is offline
This wrench doesn't require you to move the distributor:
CTA Tools 3575 Ford Ignition Module Socket - - Amazon.com CTA Tools 3575 Ford Ignition Module Socket - - Amazon.com
I'm waiting to get mine from Amazon to do this same job. I tried using an OEM ignition module wrench, and it would require me to rotate the distributor, which I prefer not to do.
Old 09-23-2015, 08:51 PM
wtroger's Avatar
wtroger
wtroger is online now
I use a 7/32's that I have turned down to fit in the hole. And yes they make a tool to for this job
Old 09-23-2015, 09:03 PM
Chasm*18's Avatar
Chasm*18
Chasm*18 is offline
I tried using the CTA tool. It easily got the front screw out without moving the distributor. However, I had to rotate the distributor to reach the rear screw. While the tool reached it, there was not enough room between the distributor and the coolant temp sensor housing to make it work. The PO had already marked the distributor position.
The OEM tool is less expensive, and would have worked just as well.
OEM/Ignition module wrench 25013 at AutoZone.com
moe67moe
10-13-2016 07:18 PM
pawpaw
Oil & Lubrication
03-02-2016 01:58 PM
1918ALF
01-01-2016 02:34 AM
phillip99
1999 to 2016 Super Duty
12-02-2015 10:17 AM
Quick Reply: 87 Ignition Control Module screws
