Oil around intake clamps of turbo
Hello,
I have a 2001 7.3 and I just changed the oil. While under the hood I noticed a lot of black oily deposits around the intake rubber and clamps going into the turbo. It was on the black rubber connector that says cool air? There was also some spray on a few tubes under the pipe.
When I was looking for a 7.3 truck I noticed that a few others had a bunch of black crud in the same area. This is obviously common. What is the issue and how do I repair it?
Thanks,
redbug
Thanks,
redbug
He is right.The factory hoses are really thin and known to leak oil and lower boost.You can fix them easily with a few mods.Look here.Give Clay a call and tell him what you need.
Riffraff Diesel: CCV Kit
Riffraff Diesel: RDP Complete CAC Intercooler Boot Kit
The residue comes from the Crankcase Ventilation (CCV). The design is to have the CCV vent into the intake air to get consumed by the engine and hopefully lower emissions. Since the boots are pre-combustion the oil eventually gets absorbed or blown through the connection and starts to make a mess. The CCV mod redirects the oily air through a hose to ambient under the truck. Most of the International trucks use this type of system exclusively. Ford designed it to be consumed to keep the EPA off of their back.
Removing the boots and cleaning them, will keep it at bay for awhile, but it will most likely come back. If you do he CCV you will need to remove the boots and clean them really good before re-installing. This will get all the residual fluid.
if your talking bout this. it is due to the crank case vent being routed into the air intake.
no biggy they all do it. your intercooler tubes end up with a oily residue inside
if it troubles you you can do the CCV mod
Riffraff Diesel: RDP CCV Kit
I went with another supplier but here it is installed. It re routes the CCV gas, filters it and returns clean air back to your intake.
while you are there wack a new set of boots on and you wont look back
looks like Im to slow, they all beat me to it.
I did the CCV 'delete' for a little while. I absolutely hated it. I love my diesel truck, but that stinky CC smell was horrid and the smoke made people think something was wrong with my truck. Screw that 'mod'!!
As far as 'CCV mod' goes, I can't see it reducing the oil on/around boots very much unless you replace CAC. I recently had CAC out for the 3rd time (at least...) and stood it on end intentionally trying to drain the oil from it - again. After 3 weeks, there was STILL oil coming out. This oil (which ain't hurting a damn thing) will always migrate thru the seal on the boots - even if ya stop 'adding' oil to the CAC. I can say that upgrading to RiffRaff boots does stop ALOT of that migration and since I've been using them all it takes is a couple squirts of diluted Purple Power and a blast from the hose a couple times a year and my engine stays almost as clean as Rick's (Miller_Feed). Of course, if ya want an engine THAT clean - you gotta avoid driving in inclement weather... (Btw, Rick does not have a CCV mod )
As to other people thinking something is wrong with my truck, WGAS? They are not paying for the truck why should their opinion matter?
