Changing windshield washer pump
Old 02-21-2011, 02:55 PM
smashclash's Avatar
smashclash
smashclash is offline
Anyone ever do it? Do you just disconnect the plug, pop off the retaining clip and pull the whole thing out with a pair of pliers from the outside? Is there any need to pop the top off and get at it from the inside? Should it just slide on or is there any type of grove it needs to slide out of?
Any tips are appreciated.
Old 02-21-2011, 04:49 PM
phoneman91's Avatar
phoneman91
phoneman91 is offline
Be sure that the pump needs replacement-my problem was a corroded connector between the body wiring and the pump. I would think that the pump can be removed from the bottom outside. Remove the reservoir from the truck and take a look.
Old 02-21-2011, 07:44 PM
barryf's Avatar
barryf
barryf is offline
i replaced mine, was somewhat of a pain. the actual nuts and clips are very easy to do. hard part was getting at the clips holding the rotating arm on the pump to the windshield wiper arms. had to undue the cowling, lift it up, get my big hands in there . not technically difficult tho
barry
TonyJestis
02-23-2019 11:06 AM
One79one71
01-03-2017 10:35 AM
ryanmikael57
1999 to 2016 Super Duty
11-01-2016 05:26 PM
TheSterling
02-13-2016 05:46 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
08-09-2008 08:31 AM
Quick Reply: Changing windshield washer pump
