MAF (mass airflow sensor) cleanup day
Old 07-09-2012, 09:37 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by king-david
Can someone tell me where the MAF sensor is on my 02 Excursion with a k&n cold air kit on it? I don't see anything resembling the picture in mine...
Do you have a gasser Ex? You don't have anything listed in your sig.
If you have a PSD, you won't have one.
Stewart
PS - It really helps us if you fill out your sig so we know your Excursions pedigree.
Old 07-09-2012, 10:08 PM
king-david's Avatar
king-david
king-david is offline
Stewart
I'm a little embarrased to say, I have no idea where to change my sig!
But I have a 2002 Ex v10 gasser. I'm going back to look for 'edit my signature'
EDIT: looks like i need some more posts!
Old 07-09-2012, 10:35 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
David, it should still be upstream of your K&N filter. Post a couple more and you'll be able to change your signature.
Old 07-09-2012, 10:44 PM
king-david's Avatar
king-david
Upstream like where?
Excuse the dirtyness...
Old 07-09-2012, 11:12 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
I think I see it here. Look at all the wires going into the tube!
Old 07-09-2012, 11:14 PM
king-david's Avatar
king-david
<runs and hides embarressed>
Thank you sir!
jh818's Avatar
jh818
jh818 is offline
Is that it right behind that plate after the filter? It has a plug and wires.
Old 07-10-2012, 09:34 AM
f150crewcab's Avatar
f150crewcab
f150crewcab is offline
Originally Posted by CrzHelm
in past 2 vehicles i damaged 2 of those mass air sensors from using k&n oil type filters. between the cost of the k&n, new air sensors, and oil cleaning kit, I would never recoupe the money spent in trying to save 1or2 mpg. just by the cheapest air filter every year and you'll be better off.
Based on advice from other FTEr's, I ditched the K&N that came with my X for the stock air filter.
Old 07-10-2012, 10:30 AM
king-david's Avatar
king-david
I thought there was another thread that said that may not actually be the case? I know k&n has done some research on it and found a significant number of things that were being blamed on them, were not them at all.
http://www.knfilters.com/MAF/massair.htm
Old 07-10-2012, 07:17 PM
king-david's Avatar
king-david
You all might be happy to know, that I successfully removed/cleaned my MAF
Old 12-31-2012, 11:48 AM
pyrodenis's Avatar
pyrodenis
pyrodenis is offline
MAF removal for cleaning?
I cleaned my MAF, but did not actually open the housing of the circuit board; didn't have a torx. So, removing the tubular housing (that's inside the section just downstream, from the filter) and spraying both thermistors, was the best I could do. They seemed to clean nicely, and I was careful not to drip in, toward the circuit board.
Does the FTE collective braintrust think that's adequate?
Old 12-31-2012, 12:24 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Yes, this portion of the braintrust thinks so.
  #28
Old 12-31-2012, 12:48 PM
jayjjcc's Avatar
jayjjcc
jayjjcc is offline
You should see some kind of wiring harness attached to your zip tube.
  #29
Old 01-02-2013, 04:14 AM
JWA's Avatar
JWA
JWA is offline
Received 1,378 Likes on 1,093 Posts
Also agree this should be more than enough. I've done it both ways with equally positive results. Fact is you might be able to do this very effectively not even removing anything other than the filter and its removable housing, just aim the cleaner directly at the MAF. Perhaps give the sensor a squirt or two when the filter is changed?
  #30
Old 05-10-2016, 07:45 AM
Ford4now's Avatar
Ford4now
Ford4now is offline
4wd Low
Don't mean to resurrect a zombie thread, but I searched and found the info I needed, so thanks to the OP. However, I want to add a note of caution to one comment I saw that said to buy the cheapest filter. I am having to do this because of the failure of the glue that holds the paper element to the 'nose cone' on the filter. Not even 20K miles on it. The failure allowed unfiltered air to pass thru the intake and eventually caused a check engine soon warning. I'm hoping that cleaning the MAF will be sufficient. The filter in question wasn't even the cheapest, in fact it was a Motorcraft. I have always been a fan of Wix air and oil and will try to stick with my tried and true in the future.
Quick Reply: MAF (mass airflow sensor) cleanup day
