1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tranny won't go into reverse
Old 02-18-2011, 10:39 PM
Horizon09's Avatar
Horizon09
Horizon09 is offline
2002 f350 w/ 7.3l, 4x4,extended cab long box..... Drove for 1/2 hour, went to back up, wouldnt go, noticed tranny temp guage almost to the yellow, still go's in drive, I checked the tranny fluid, was very low, added 3 litres still no reverse, no leaks under truck, when i put it in rev. It revs up as if it was in gear but no go, very confused! Plz help
Old 02-19-2011, 04:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
First off we can eliminate anything electronic. All the sensors and solenoids can't keep it from going into reverse. It's probably a seal in the reverse clutch, though it could be something broke in the reverse clutch, too. I would have to tear the trans down to be sure.
Old 02-19-2011, 06:59 AM
Horizon09's Avatar
Horizon09
Does it sound right if the fluid didn't even show up on the dip stick that it would take 3 litres to fill it? Is it possible to burn that much fluid in three months time?
Old 02-19-2011, 08:33 AM
Mark Kovalsky
It isn't possible to burn oil in the transmission. It has to be leaking somewhere. With the engine COLD check for oil in the coolant. A common leak point is the trans cooler inside the radiator.
Another thing to check is if the transfer case is overfilled. The seal between the trans and transfer case can fail and the trans will lose oil to the transfer case. The way to check this is to remove the fill plug on the transfer case. If about three quarts run out, that's where you lost your fluid.
Old 02-20-2011, 09:33 PM
Horizon09's Avatar
Horizon09
Thanx Mark.. That gives me some where to start... If it is the reverse clutch will i do more damage driving it to the shop?
Old 02-21-2011, 03:45 PM
Mark Kovalsky
My guess is that it won't cause any more damage.
stoven
04-22-2014 08:48 AM
sf76
12-02-2012 08:32 PM
tulsatonyfan
1997 - 2003 F150
11-19-2011 11:40 PM
H1449-6
04-15-2009 02:51 PM
skinsey
03-27-2004 12:44 AM
Quick Reply: Tranny won't go into reverse
