Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
2006 - 2008 Ford F150 Truck Wheel Bearing & Hub Assembly MOTORCRAFT
Old 02-18-2011, 12:36 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
PLEASE CHECK OUT WEBSITE FOR CURRENT PRICING
2006 - 2008 Ford F150 Truck Wheel Bearing & Hub Assembly PAIR Front for Models with 6 Lug Wheels ( Motorcraft)
Ford/Motorcraft: HUB30 (PAIR)
These wheel bearing and hub assemblies are FORD original equipment parts! It is the same part that you would receive if you purchased it from your local Ford dealer!
Specifications:
Brand NEW Ford/Motorcraft parts
Comes as a PAIR
Includes the LH (Driver) & RH (Passenger) Side FRONT
Replaces dealer part numbers: 7L3Z 1104 A, 7L3Z1104A
Direct replacement
4 Bolt Rectangular Flange
Fits 6 lug wheel
New wheel studs already installed
Has ABS (Anti Lock Brakes) sensor already installed
Note: For 2005 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
Quality
1A Auto exclusive 2 Year Warranty.
If this hub bearing should fail to provide satisfactory performance you may exchange it.
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. If you would like, you can Click the BBB or Bizrate icons in the top right. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto hub bearings are all tested prior to shipping.
1Aauto
11-22-2013 01:56 PM
1Aauto
05-21-2013 10:38 AM
1Aauto
05-21-2013 10:33 AM
1Aauto
02-06-2013 03:34 PM
1Aauto
02-18-2011 11:00 AM
Quick Reply: 2006 - 2008 Ford F150 Truck Wheel Bearing & Hub Assembly MOTORCRAFT
