Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Pa inspection question
Old 02-18-2011, 11:03 AM
sckootter16's Avatar
sckootter16
sckootter16 is offline
Hi fellow pennsylvaniens I have a question about exhaust for pa inspection. I am redoing my exhaust on my 81 ford f150 . I live in butler county and no emission check. My question is for the tail pipe.I know I have to run the piping past the cab. Do I have to have a tail pipe running to the outer side of the truck or can i just have a turn down off of the muffler under the bed. I am putting a flow master super series 44 on my truck and I want some sound. I was going to just have a turn down off of the outlet side of the muffler and not worry about a tail pipe but I dont know if it would pass inspection. So please let me know thanx.
Old 02-18-2011, 12:10 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I found this:
(i) Exhaust system and discharge location. Exhaust systems are not permitted to discharge to the atmosphere at a location immediately below the fuel tank or the fuel tank filler pipe. Exhaust systems shall also extend and discharge completely to the outside edge of the vehicle body.
here:
067 Pa. Code §*171.21.*Exhaust system.
Also found this bit in the inspection procedure (link):
(6) Inspect the exhaust system and reject if one or more of the following apply:
(viii) The exhaust does not discharge to the outside edge of the vehicle body, including a truck bed, or as originally designed, except for the following:
(A) Heavy trucks or truck tractors. The exhaust system of every heavy truck and truck tractor shall discharge to the atmosphere at a location to the rear of the cab or, if the exhaust projects above the cab, at a location near the rear of the cab.
(B) Gasoline powered buses, including school buses. The exhaust system of a bus powered by a gasoline engine shall discharge to the atmosphere at or within 6 inches forward of the rearmost part of the bus. Until June 15, 1998, the tailpipe of school buses may extend to, but not beyond the body limits on the left side of the school bus within 60 inches of the left rear wheel as measured from the center of the wheel axis.
(C) Buses, including school buses, powered by fuels other than gasoline. The exhaust system of a bus using fuels other than gasoline shall discharge to the atmosphere either at or within 15 inches forward of the rearmost part of the vehicle; or to the rear of all doors or windows designed to be opened, except windows designed to be opened solely as emergency exits. Until June 15, 1998, the tailpipe of school buses may extend to, but not beyond the body limits on the left side of the school bus within 60 inches of the left rear wheel as measured from the center of the wheel axis.
Old 02-18-2011, 01:11 PM
thomabb's Avatar
thomabb
thomabb is offline
I was going to put up the state vehicle code, but someone is faster.
I live in Butler also. Go over to Iarrapino's. They can make a custom pipe for you for the muffler back. It's been a couple years since I have used them, but I think they are still the place to go for exhaust work around here.
Old 02-18-2011, 07:11 PM
503racing's Avatar
503racing
503racing is offline
whatever was on it stock has to be there and outside the body behind the cab. if you had cats punch them out, modded my exhaust eliminating stock parts even with a 5000 mile or less exempt and they told me i needed them. guess it depends on where you go in all honesty,some shops will just say"tell them you did it afterwords"
Old 02-18-2011, 11:02 PM
sckootter16
Cool thanx guys. Thomabb where in butler county do you live? I guess I will check Iarrapinos. thanx for all the help.
Old 02-20-2011, 09:12 AM
thomabb's Avatar
thomabb
thomabb is offline
Oakland Township. I can see St. Wendelins Church and the golf course from my yard. You?
Jason302
05-26-2011 07:14 AM
IZZYAZ
10-15-2009 09:45 PM
SteelHorse08
2004 - 2008 F150
03-12-2008 08:45 PM
PCWest13
Exhaust Systems
10-13-2003 10:33 PM
jimbo81587
Exhaust Systems
10-08-2003 12:50 PM
Quick Reply: Pa inspection question
