What are the buttons on the center console gear shifter?
Old 02-17-2011, 06:26 PM
soundwave's Avatar
soundwave
soundwave is offline
Ive noticed while looking at online photos of the 2011 F150s, that on the FX4 and above trim levels, there are 2 sets of buttons on the center gear shifter. On mine, there is only one for tow/haul mode. I can make out in the pictures that its still there, but what is the other button?
Old 02-17-2011, 06:34 PM
JesseJFX2's Avatar
JesseJFX2
JesseJFX2 is offline
Just a shot in the dark, diff lock maybe?
Old 02-17-2011, 07:01 PM
bipock's Avatar
bipock
bipock is offline
The other button on my Lariat is the manual mode shifter. Instead of moving the shifter side to side, it's button controlled. Or so i think.
Old 02-17-2011, 09:22 PM
jmmec's Avatar
jmmec
jmmec is offline
Pretty sure you are referring to the SelectShift transmission -- as above, if you put the truck in "M" (manual), then you use it to shift gears up/down. If you are not in "M", then you can also use it to see what gear you are in (on the LCD screen), and you can also cancel higher gears (e.g. cancel 6 and 5, then the truck will only use gears 1-4).
Old 02-17-2011, 09:28 PM
soundwave's Avatar
soundwave
Something new?
Old 02-18-2011, 05:44 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,218 Likes on 801 Posts
Originally Posted by soundwave
Something new?
This started with the 2011 models.
Old 02-18-2011, 11:10 AM
Toto's Avatar
Toto
Toto is offline
It may be the tow/haul, but your owners manual will tell you.
Old 02-18-2011, 02:31 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
The top button with the +/- is for the manual shift mode. The button with the T/H is for the tow/haul mode.
Old 02-18-2011, 02:38 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
Love it, cant wait to buy one.
Old 02-18-2011, 07:56 PM
soundwave's Avatar
soundwave
Thank you. Thats what I was refering to. Because my '10 only has the tow/haul, there isnt an owners manual for me to look into.
Now...how does the manual shift work? Whats your opinion?
Old 02-18-2011, 11:31 PM
81beast's Avatar
81beast
81beast is offline
The Selectshift is great. I don't own one yet but I have one on order in my 2011 FX4 EB. I have driven a 5.0 with a console Selectshift and a EB with a column Selectshift and the console is much better for me.
It allows you to manually shift all gears with the up and down switch while in manual mode. It also allows you to lock out gears. If you are towing and you notice the truck hunting for gears between 5th and 6th, then lock out 6th and the transmission will never shift to 6th. Or lock out 5th and 6th if needed, etc.
My opinion? I am selling my 6.8 V10 SD with a 6 speed manual trans for a 3.5EB F150 with the Selectshift on the console. I like to have control over my transmission and Ford has finally given me the control I need with this automatic.
sanman1969
12-10-2020 12:32 PM
Ctkid
04-01-2017 11:12 PM
lilrobo
20
07-24-2013 08:10 PM
TTARP
08-19-2011 11:02 AM
BlackFX4Screw
2004 - 2008 F150
12-15-2009 06:35 PM
Quick Reply: What are the buttons on the center console gear shifter?
