wmo
Old 02-12-2011, 06:12 PM
Fireman_dave's Avatar
Fireman_dave
Fireman_dave is offline
wmo
i assume from reading wmo is waste motor oil, i have a 7.3 idi diesel, and i am a maint man at a foundry, i take care of 30 diesel forklifts serviceing them every 200hrs , with a service it gets an oil change and the trans fluid changed..and it all gets dumped into a 55 gal drum, there might ever be a bit of hyd oil in there too....how would this combo do?, i know when i change fuel filters on the diesels i always use tranny fluid to fill the filter
Old 02-12-2011, 08:18 PM
bradyracing's Avatar
bradyracing
bradyracing is offline
I'm just curious. When you change filters on a diesel, you always fill the filter with tranny fluid? Why not fill the filter with diesel?
Old 02-13-2011, 07:52 AM
Fireman_dave
thats the way i was taught with a diesel....supposedly atf has some real good solvents in it and with it being thicker than diesel it will clean out the injectors...is this true or not.....i dont know.....but i always have done it
Old 02-13-2011, 12:01 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
armstrongfordtrucks is offline
ATF I have heard is the best diesel injector cleaner available. I run WMO in my 2000 7.3, however I would run nothing but ATF if I could get my hands on it. I believe it is the same viscosity as diesel. WMO is to thick at 30* to start the truck outside unless you keep it plugged in. I am in no way recommending you run anything except diesel in your truck though. Could trash your fuel system. I only have logged 10,000 miles so far, don't know the consequences yet.
'88 E-350
Bio-diesel, Propane & Alternative Diesel Engine Fuels
47
09-10-2022 10:28 AM
10thMountainMechanic
28
09-08-2014 05:27 PM
timmyboy76
04-15-2014 05:27 PM
joshofalltrades
51
03-03-2013 12:21 AM
ghunt
12-28-2009 06:56 PM
Quick Reply: wmo
