1949 F3
1949 F3
Im getting ready to start working on my 49 f3. Its going to be a driver (not racer) just jump in anytime and drive. its going to have a 1980 351w with either a c4 or c6 not sure that yet. im looking at trying to keep close to the same ride height. im looking at converting the front to discs with the speedway kit. planing on running the 5 on 4.5 pattern. il have full moons so the pattern wont be seen. for the rear i either have a '86 ranger axle or i have a '79 cougar 9". the cougar is still a complete car and im parting out the ranger so im thinking on using that. any commets on this build.
also i was wandering is there a adapter kit to put a grant steering wheel on the stock steering colum
a few pics
a few pics
there is a little bubbly rust on the rear fenders and little bit here and there but nothing to bad. it also has the factory grill gaurd in the back. i want to use that since its not common for people to use them. i paid $650 for the truck back in febuary of '08 just now starting to get in tho the project. im planning on useing the tires and moons that came with it just need different 16"rims that have the 5 on 4.5 pattern. also there is no bed in the truck so im trying to figure out what to do there. i got a bunch of that composite wood(grey in color) thinking that would look kinda cool
Nice looking truck. I personally advocate keeping things mostly stock. For your rear axle swap you will find that the 9 inch from 57 to 72 F-100 pickups is the correct width. You will then need to get axles with the bolt pattern you want and swap them into the housing. Why don't you want to go with 5 on 5.5 inch pattern?
F-3
Good luck. I recently completed my F-3 that I started in 2004. Kept mine mostly stock except swapped out the rear end for a dana from a 72 Ford and found original stock 16" from a 52 F-250 to replace my 17" split rim widow-makers. Love the truck - can't wait for the snow and ice to melt
on
Classic Performance Parts.
Disc Brake, Steering and Suspension Products for classic Chevy and Ford cars and trucks
Welcome. Looks to be in good shape. It's nice to see more F3s out there. I have a 48 that I just got. I'm going with the Dana 60 swap with 16" rims from an F2.
Could you post a picture of the factory grill guard? I got a grill guard with mine and was wondering if it was factory. I am also thinking of using it. Does it look anything like this?
steveFord49F3Pickup,
Any insights to share on the Dana swap? I got mine from a 69 F250. Was it a straight bolt-in, or was there some fab work to do to do?
