3 Inch wider 56 ford f100 fenders
Sorry if this posted twice. Anyway, looking for some help on these fenders if anyone has used them. Theyre glass fender 3 inches wider from mid fifties fords. Im told theyre made by gibbons. Also, if i use these do i need to change my running boards to match up with the wider fender.
thanks,
Mike
thanks,
Mike
This truck belongs to a customer, I just straightened the fenders and painted them. I believe that he bought them at a swap meet. A word of caution...these fenders were very wavy and took a lot of sanding to make them straight. I can't help you with a recommendation for a particular vendor but whatever way you choose to go take a good look at the fenders (or better yet have your body/paint guy look at them) especially for how true they are where they attach to the bed. If you are not running welting like this truck then you better have a flat mating surface.
Oh yeah, as an added note....I sprayed the inner surfaces with bedliner to add some protection to the glass, rock chips can work on FG over time.
I posted in the duplicate topic.. these were made by Fairlane from detroit,
no longer in business, and Bebops Glassworks in Tennessee.. I got mine from Bebops direct.. altho everyone sells them (MF, Carpenter, LMC...)
my set were perfect..
like Charlie, I sprayed the inside of mine with clear Chipguard to protect them
Sam
Sam
Just to give you an idea of how bad these fenders were when I got to work on them here's a pic... The black sections are the high areas that had to be ground down, that is actually the fiberglass showing through. I would like to believe that this was just an aberration but I know that I would really look them over before handing them off to the body shop.
Sam, how were your fenders when you bought them? Hopefully a lot straighter than these. Ooops, just read your post...glad to hear that yours were perfect!
I've prepped a lot of fiberglass parts for paint over the years and they all tend to be somewhat wavy. Gibbons used to make some good parts, haven't worked with Bebops, and Fairlane (no longer in business) used to come and go on their quality. I've got a glass front end from Fairlane that is awful, the glass rear fenders were better, but still had some waves.
Definitely coat any glass fender with a couple of coats of a rubberized undercoating unless you like seeing star checks in your finished paint after a few days on the road. Ask me how I know.
SEM Products 39793 Heavy Texture Chip Guard, Aerosol
I also did the front of the cab at the fenders to protect the paint from rock chips
Sam
Steve Bennett
11-08-2016 01:26 PM
craftsmangary
09-15-2016 05:40 PM
