1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
brown wire mod on A4WD
Old 02-11-2011, 01:16 AM
78ecf250cs's Avatar
78ecf250cs
78ecf250cs is offline
Does anyone have any info about a wire modification on an a4wd system on a 99 expedition. Someone asked if it was done to my expedition in another thread, and I know nothing about it and did not get a response from them. So i thought id see if anyone might know something about it.
Old 02-11-2011, 12:09 PM
98EXPY 5-0's Avatar
98EXPY 5-0
98EXPY 5-0 is offline
If your truck doesn't have a 2WD option on the dial, cutting the brown wire (or putting a toggle switch in) will disable the front drive clutch when it's in AWD so you can stay in 2wd, even with slippage.
Mine has 2wd, so that is all I know.
Old 02-11-2011, 02:31 PM
78ecf250cs's Avatar
78ecf250cs
Thaks for that info. Is the brown wire that is to be cut at the switch or at the transfer case or axle?
Old 02-11-2011, 06:22 PM
alloro's Avatar
alloro
alloro is offline
Received 4,201 Likes on 2,436 Posts
Originally Posted by 78ecf250cs
Thanks for that info. Is the brown wire that is to be cut at the switch or at the transfer case or axle?
This rather lengthy thread should be able to supply you with any answers for the brown wire mod.
https://www.ford-trucks.com/forums/1...ition-4x4.html
Old 02-12-2011, 12:38 AM
78ecf250cs's Avatar
78ecf250cs
Thanks alloro that helped alot.
FarmLaw
141
11-14-2023 08:02 AM
mbkabbasi
New Member Introductions
04-12-2016 03:25 PM
mjkorcek
03-24-2016 04:31 PM
TExpedition45
18
06-10-2015 08:47 PM
taykowski
10-26-2011 11:19 PM
Quick Reply: brown wire mod on A4WD
