I need to replace my passenger side rear seal and possibly the bearing. Is this a DIY driveway fix or do I need a hydraulic press for the bearing. Could someone give me a play by play on this job? How many hours? etc....
its pretty easy man take ur tire off brake drum an ur axle will have a hole n it there are 4 nuts take nuts off an slide axle out an yes theres a sleve collar that holds plate on an it an bearings r pressd u ought 2 be able handle it
its a pretty simple job dude u ought 2 b able 2 do it
