fanbelt diagram 6.9l
Theres so many ways to put belts on these.
My 7.3 with no A/C
First belt closer to radiator goes from: Crank to Fan, from Fan to P/S pump.
2nd belt (middle one) goes from crank, fan, then vacuum pump
3rd belt closer to block goes from crank, fan then Alternator.
My Alt has a dual belt pulley but haven't really used it.
On my Factory (not dealer) A/C 6.9
First belt closer to radiator goes from crank, fan then A/C compressor
2nd middle belt goes from crank, fan, then P/S pump
3rd belt closer to block goes from crank, fan, then Alternator
Then theres a 4th small belt from the Alt that goes straight down to the vacuum pump.
I am pretty sure that's how they are from the factory.
My 7.3 with no A/C
ok thats how mine is - the ac part i thought maybe someone changed up the belts as 1 is a cog not a smooth belt
My 7.3 with no A/C
Yup, both Alt and P/S pump on the 7.3 have dual belt pulleys.
It's my dad that set 'em up like that on the 7.3 when he changed for the very first time the belts on it. He thaught it would be a better settup than having that little belt drive the Vacuum pump from the Alt. He found it pretty useless to have 2 belts driving the P/S pump for his application.
So each acceserie has it's own belt off the crank/fan.
