7.3 powerstroke cam sensor issues?
Old 02-04-2011, 01:14 PM
seanj5202's Avatar
seanj5202
seanj5202 is offline
i have a 99 f250 7.3 powerstroke. the cam sensor was acting up. that what the scan tool said. i replaced the cam position sensor yesterday, and the truck is still acting up. the motor hitches and will shut off randomly. it tripped the check engine light, and the code is the "cam position sensor" once the truck is warmed up and shut down for like 10 minutes the sensor will not act up anymore. if i just start the truck and run it, even once it is up to tempature it will act up. but if i shut the truck down for about 10 minutes, it goes away. is there something else that could be causing this? thank you
Old 02-04-2011, 01:28 PM
Trucky2's Avatar
Trucky2
Trucky2 is offline
Did you get an OEM CPS or maybe something from an auto parts store? There's lots of discussions regarding this in the 7.3 forum. Some say the aftermarket CPS units have not worked right for them and swear by one of the OEM versions.
Old 02-04-2011, 02:05 PM
seanj5202's Avatar
seanj5202
i got this sensor from napa. ill check out the 7.3 forums, thanks
Old 02-04-2011, 02:12 PM
SC74's Avatar
SC74
SC74 is offline
Did you disconnect your battery when you installed it. I've heard that you need to disconnect the battery for aprox 30 min to reset the computer so it re-learns the new sensor.
Old 02-04-2011, 02:31 PM
seanj5202's Avatar
seanj5202
i didnt disconnect the batteries, but i read somewhere to pull the #9 fuse under the hood? can i still disconnect the batteries now, will the computer recognize the new sensor?
Old 02-04-2011, 03:12 PM
seanj5202's Avatar
seanj5202
also should i remove the sensor and coat it in vasoline? i only coated it in oil before inserting it into the motor. thanks
Old 02-04-2011, 06:11 PM
F350-6's Avatar
F350-6
F350-6 is offline
You don't need to disconnect the batteries. If the CPS is good then the PCM will see the tach signal and everything will be fine.
If you want to put vaseline or di-electric grease on something, it goes on the rubber gasket at the plug connector. This helps provide a better seal that will keep moisture out of the electrical connection.
And as Ken originally said. Too many problems with the aftermarket CPS from places like NAPA etc. Stop by Ford and you should be able to pick one up for around $25.
Old 02-04-2011, 07:44 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old 02-05-2011, 12:41 AM
aklim's Avatar
aklim
aklim is offline
That could be an issue. From what I heard, either get them from International or Ford.
Old 02-05-2011, 01:30 AM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
Stay away from the aftermarkets. Seen too many of them have issues. Make sure the code reader you are using is PSD compatible. If not, it may not even be reading the codes right. Your problem does sound like a CPS, but there could be other things that cause it.
Old 02-05-2011, 01:52 AM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Here is a good link for you that will help you know the difference between different CPS sensors.
Black CPS proves to lower PERDELS again
Old 02-05-2011, 06:59 PM
seanj5202's Avatar
seanj5202
where can i pick up a "black" cps? from a ford or international dealer?
Old 02-05-2011, 08:01 PM
szotty's Avatar
szotty
szotty is offline
dont think you can get black one from anyone other than clay at riffraft or bob at diesel orings
Old 02-05-2011, 08:09 PM
zx250's Avatar
zx250
zx250 is offline
Clay has them and his link is in my signature.
Old 02-05-2011, 08:42 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Flip a coin.
Heads Dieselorings - Tails Riffraff
Dieselorings Black CPS
Riffraff Black CPS
Quick Reply: 7.3 powerstroke cam sensor issues?
