6.2L V8 Discuss the 6.2L V8
tires & 6.2
Old 02-03-2011, 07:30 PM
vtragweed's Avatar
vtragweed
vtragweed is offline
tires & 6.2
with the 6.2 and the 4:30 gears will a 33' tires knock it down to a 4:10 and result in better mpg?
Old 02-04-2011, 09:21 AM
Radioactive 4x4's Avatar
Radioactive 4x4
Radioactive 4x4 is offline
A 275/70/18 tire is a 33" tall tire. Metric To Inches Tire Size Conversion I think maybe going to a 35" might do the trick. That is what I am planning.
Old 02-04-2011, 09:48 AM
Scrming's Avatar
Scrming
Scrming is offline
How much heavier will the taller tires be? If they are heavier then it would most likely offset any kind of fuel savings. The things is extra weight in the tires is not simply dead weight, it's rotating weight which is something like double... so if you r new tires weight 5 pounds more that's really like 10 pounds of dead weight... times that by four... Of course I realize there that is still very small compared to the overall weight of the truck.... But then again how much difference in MPG is there between the 4.30s and 4.10s?
Also probably going to want to have the computer changed to reflect the taller tires to correct the speedo...
jowens1126
6.2L V8
05-03-2017 08:54 PM
Fmc4lfe
2017+ Super Duty
02-10-2017 08:18 PM
carlhwv
1999 to 2016 Super Duty
28
10-15-2016 11:00 AM
stufarmer
16
10-01-2016 10:22 PM
gustrider4
16
01-18-2016 11:12 AM
Quick Reply: tires & 6.2
