1965 ford econoline engine swap
Old 02-02-2011, 02:19 PM
oklahoma rgs's Avatar
oklahoma rgs
oklahoma rgs is offline
Will a 240 or a 300 fit in the spot of a 170 with no motor mount issues. If not what will it take to do this?
Thanks
Old 02-02-2011, 03:30 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,103 Likes on 2,165 Posts
the 240/300 is quite a bit larger than the 144/170/200 engines.
i think you will need to do quite a bit of fabrication to fit one in the engine box.
your better bet would be a 200 or 250 six, or a small V8 like a 289 or 302
Old 02-02-2011, 04:25 PM
socalwrench's Avatar
socalwrench
socalwrench is offline
Agreed, don't bother with the 240. You can get plenty of torque from a 200, or 250 for that matter.
Old 02-02-2011, 05:40 PM
66gpw's Avatar
66gpw
66gpw is offline
If it is a 65. those engines will fit in the doghouses no problem. I cannot say about the motor mounts. The crossmember is a tube style in that year. which are shared by all those engines. Just different motor mounts to the block.
Also the rad is bigger for the 240 and 300.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 1965 ford econoline engine swap
